Mounting Hella 4000s with Stock Bumper/Brush Guard - Defender Source
Old June 1st, 2004, 06:29 PM
jbird
Justin Bird
94 D-90 ST
Has anyone mounted Hella 4000s to the stock bumper/brush guard? In searching through the forum archives and postings, it seems that aux. lights are typically installed via the LR light bar. It also seems that the LR light bar cannot accomodate Hella 4000s without cutting holes the grill. If someone has installed Hella 4000s with a stock bumper/brush guard, how did you do it? Is there a way to do it without cutting holes in the grill? Thank you.
Old June 1st, 2004, 06:35 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Weld a couple of light mounts on the brush bar.
Old June 2nd, 2004, 11:55 PM
gearco
James T. Johnston, Jr.
1986 D110
i have an A bar on a winch bumper. i drilled two holes under the A bar equidistant from the outside curves and used a nutsert tool to install an 8mm nut inside the holes in the bar. bolted two Hella 4000 lights hanging down inside the A bar and it looks good. IMHO you don't want to weld tabs to the brush guard because it is powder coated and you will burn the plastic. also if you weld tabs to the back of the brush bar, you don't have much room between the grill and lights.
Old June 10th, 2004, 02:12 PM
jbird
Justin Bird
94 D-90 ST
As a follow-up, I ordered the 4000s and brackets from denunzio racing. Both are priced well and the brackets fit perfectly on the crossbar on the stock brush guard (94). I had the brackets welded on this morning and now just have to install the wiring harness. Thanks D90.
Old June 10th, 2004, 02:50 PM
sachilles
Seth Achilles
87 RRC
My friend didn't seem to have a problem mounting his. Just drilled two holes in the lower cross bar. Fit fine.
Old June 10th, 2004, 06:01 PM
For those bumper without the light provision on the brush bar. there is another bar that mounts on the bumper inbeetween the brush bar and the bumper, if using this method the 4k wont fit.
brush guard, bumper, mount
Stock tire Carrier Mounting Bracket Joe P Wanted 2 September 8th, 2005 08:11 PM
94 brush guard and bumper (stock) cdnpaul For Sale - Parts 0 November 7th, 2004 02:57 PM
97 brush guard and bumper (stock) Seriesman For Sale - Parts 1 November 1st, 2004 01:10 AM
Mounting hi lift jack to Brush guard Cyborg Defender Technical Discussions 12 May 3rd, 2004 10:09 AM
Stock Fuel Tank Guard willtillery Wanted 0 February 23rd, 2004 11:31 AM
