Mounting Gas Cans on a D90 - Defender Source
Old August 31st, 2009, 10:36 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
Was out exercising the D90 this past Saturday. Started out with a full tank of gas but after 6 hours driving the trails I made it to a gas station with only a gallon to share. No one else in the party had gas cans. I once saw a picture of gas cans mounted on a D90 but the rack used is no longer made. Anyone have any ideas, pictures, rack manufacturers or what ever for mountinh gas cans. By the way, CAN'T mount them on the roof!
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old August 31st, 2009, 11:05 AM
Rugbier's Avatar
Rugbier
Gustavo
I adapted a Safari Guard hi-lift mount on the spare tire.
NO SIGNATURE
Old August 31st, 2009, 11:11 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've toyed with a few options,, here are the links to my projects:
http://www.cj-3a.com/fabricating_a_gas_can_carrier.htm
http://www.cj-3a.com/more_rear_tire_carrier_mods.htm
I also designed the "Back Rack" which is a carrier that puts the spare tire inside along with a jerry can. The tire can come out and you can mount several more jerry cans. Obviously this won't with a SW or if you want to run with your top on.
I've seen Gustavo's - That's another good way to mount a can. I would just worry about the extra weight on the back.
ID:	21275   Click image for larger version
ID:	21277   Click image for larger version
Semper Fi!
Old August 31st, 2009, 11:16 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'm not a fan of petrol hanging off the back of my vehicle. I just do not trust people to not rear end me.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 31st, 2009, 11:34 AM
phoenix37's Avatar
phoenix37
john
http://rides.webshots.com/photo/2755...84629383wvPMSP
I dont think they would hit the cans if you got rear ended. Unless it was a bus or an 18 wheeler and in that case this would probably be the least of your worries.
Old August 31st, 2009, 01:02 PM
cdb
Clark Bowen
Or a lifted, big tired American 4wd - plenty of those around here.
I also wonder how much weight you raised up with those 2 cans and a bigger tire. I'd think 80 lbs plus over stock. Having rolled I'm very leery of higher centers of gravity and I'm with Tom about carrying a highly volatile substance unprotected. Remember the Ford Pinto exploding after being rear-ended? That's why gas tanks in newer vehicles are better protected.
Two of the reasons I was glad to install a 300 TDi were range and a less volatile fuel
2011 RR HSE -
2001 GMC 2500 4wd
Old August 31st, 2009, 01:18 PM
phoenix37's Avatar
phoenix37
john
Fair enough. I dont actually run the cans on there just a photo of the truck before I bought to give Doug some mounting suggestions.
Old August 31st, 2009, 01:21 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
How did you modify the Safarigard mount? Any pics?
Old August 31st, 2009, 02:32 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I have interested in this for a while but haven't found any solutions.
Bill
Old August 31st, 2009, 06:12 PM
Rugbier's Avatar
Rugbier
Gustavo
Clarence,
I will dig for pics , but was very simple, have welded 2 U shape braces from behind the SG mount to the back of of the can holder ( so I can have access to the hi-lift.I took it out as I have a Roof Rack now ( wonder from whom *LOL* ) so I will carry the cans on the roof )
What I am using the brace now id for the Shovel and the AX
NO SIGNATURE
Old September 15th, 2009, 03:40 PM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
Safari Gard (good luck) makes a good rack if they are still in business. I like mine and only fill the cans right before hitting the trail. It also carries a Hi-lift and I have seen them modified to carry a pull-pal. I plan on getting some locking can carriers welded to where the cans mount for safety and security.
Hey CDB, I am the guy who bought your air lockers (can't wait to get home and install them)
Name:	Zion June 10-14 2009 138XXX.jpg
Old September 15th, 2009, 04:10 PM
cdb
Clark Bowen
Hello Jon......
Plus nobody, normally, tries to blow you up while you are offroading over here.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 15th, 2009, 04:38 PM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
You may have to watch out for E.L.F. over there...they get kind of crazy and would probably like to blow up the offroad crowd....
Wizard, check out this site
http://fourtreks.com/modular_gerry_c...bar_mount.html
You may be able to come up with a way to mount them or if you talk to them see if they can customize them to fit your needs if you don't want a whole new tire carrier. Although at that point it seems like Wolfs tire carrier mods would be better.
I have also been looking into an extra tank. I have been informed that the under passenger seat aux. tank may not be the best due to ground clearance issues. (Clark gets the credit on that one)
I have also seen a S. African company that makes aux. tanks that fit in the rear fenders/quarter panels.
Another option I have been considering is welding in a frame from the chassis to the sliders and cutting the rear fenders and making a door so you can slide jerry can in. (like a 3 door MOD 110)
I really need a TDI
Old September 15th, 2009, 06:15 PM
Cmikefly
William Challancin
97 NAS D90
Custom swing away
I designed this one out of cardboard and had it fabricated in Dubai. My goal was to maintain the best possible departure angle. (I guess it could have been a bit better if I totally scrapped the original rear bumper) Instead I chose to keep it and add end caps to fit my needs. The spare tire bolts up to a complete stub axle / hub / drive member assembly for spare parts. There are also provisions for a high lift across the top similar to the SG units.
It works great as is however I would make a few small tweaks if I were to do it again. There was a small miscommunication between myself the fabricator so the slam ramp had to be redesigned and bolted on instead of a smaller welded design. (the bumper had already gone to powdercoat) I think there could be a simpler way to support the free end of the swing arm. Also the high lift could have mounted vertically on the right side with the foot of the jack sitting on the swing arm next to the pivot. I copied the idea of the hold open device from the hood prop. Works a charm.
All and all I think I made out fairly well for $750
ID:	21547   Click image for larger version
ID:	21549   Click image for larger version
ID:	21551   Click image for larger version
William Challancin
Al Ain, United Arab Emirates
1997 NAS D90
2005 110 TD5
Old September 15th, 2009, 06:31 PM
GYM's Avatar
GYM
Gary
97 SW
Nah. Messing with a few Rover guys in the Tillamook forest doesn't have the same media appeal as toppling radio towers, burning luxury homes and torching university horticulture department buildings...
Old September 15th, 2009, 10:51 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I really need a TDI
I have used a few things from fourtreks mounts; hi-lift, dual tool (shovel and ax), and fire extinguisher but that was on a FJ Cruiser. The fourtreks stuff never looked right on my Defender. So I sold most of it off. But they do sell good quality billet AL stuff. And they sell a nice pull pal mount too.
90, d90, gas, mount
D90 gas tank hole fix hlamar Defender Technical Discussions 26 May 20th, 2010 04:19 PM
spring cleaning- D90 parts Chris Cox For Sale - Parts 13 April 4th, 2005 01:51 AM
