Mounting Belt Rails??? - Defender Source
Old December 28th, 2010, 01:05 AM
2yellowlabs's Avatar
2yellowlabs
Rob
92 RRC, 99 DII, 06 LR3, 09 LR2
Any tips? How are these positioned? Right up against the steel caps on the tub? Centered left to right?
Pics?
Thank you -
Thank you -
Rob
Old December 28th, 2010, 07:13 PM
Rob, on the only example I have, the rail is centered between the front edge of the tub and the forward edge of the rear vertical capping.
hth
charles
Old December 29th, 2010, 01:27 AM
2yellowlabs
Rob
Thanks! So basically centered L to R.
Any space between the bulge in the cap and the top of the belt rail or are they just pressed right up tight to it?
Thank you -
Rob
Old December 29th, 2010, 08:19 AM
I wouldn't say centered, because of the width of the edge of the rear capping it's really closer to the front by about an inch. In my case the front of the rail is about a 1/4 inch away from the front edge of the tub, just in line with the bulge of the top tub capping.
It is pressed right up against the top capping.
I think these things were added at the dealerships and could be all different though, and I'll warn you that I have not tried a soft top with these yet. Maybe wait for someone else to confirm theirs is this way too?
mount
Belt rails and misc for Best Top 2yellowlabs Wanted 5 December 14th, 2010 10:31 PM
Bench Seat & Seat Belt Bracket Feeler jefhuf For Sale - Parts 35 August 30th, 2010 11:01 PM
Safari rack basket & front rails for sale jam90 For Sale - Parts 16 December 8th, 2005 01:23 PM
rear bench seat for D-90 SW GriffCA Defender Technical Discussions 22 June 2nd, 2004 01:40 AM
