Mounting a CB antenna on a 1997 D90 SW? - Defender Source
Old January 8th, 2007, 03:00 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Right now I have my CB antenna mounted on the stock front bumper - I'll be switching over to a RockWare bumper soon - so I'd like to look at new options for mounting - In my opinion the front bumper seems to be a bad location.
For those with CB radios... where and how did you mount your antenna?
Looking for a good solution. I don't really want to penetrate thru the body panels.
I've been thinking about making a bracket and mounting it to the rear bumper.
Any thoughts, ideas or pictures would be great.
Thanks.
Paul
Old January 8th, 2007, 03:03 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Front bumper is bad for reception, good for dense east coast trails. I have one antenna on the bumper and one on the roof. The one on the roof is folded down when in the woods unless I'm stationary.
TJM makes a nice aluminum bracket that fits well with the rockware bumper. However I would have welded a tab if I could do it over again.
Old January 8th, 2007, 03:05 PM
I made a mount and attached it to the rear tire carrier, where it bolts to the body... You could make a custom attachement to your tire carrier too.
Or, go by the glass mounted antenna (looks like a carphone antenna). I did that for my Yukon XL. I really works well.
Old January 8th, 2007, 05:45 PM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
I use a glass mounted antenna (car phone appearing) on the right rear window. Works well. No problems for a few years.
Jim
Old January 8th, 2007, 09:49 PM
bweaver
There's a mount out there somewhere for the license plate light (base sits on top). That's what I'm going with.
Old January 8th, 2007, 11:34 PM
Mark M
Mark Mathews
'94 Beluga Black ST
I had the guys at Rover Accessories fabricate a mount that bolts onto part of the tire carrier mount.
ID:	7825   Click image for larger version
Old January 8th, 2007, 11:45 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I took a Radio Shack mount, the one with the U-bolts, and modified it to fit on the swing arm. It was a total pain in the ass--I used a bit of steel bar, which was difficult to cut and drill--but it seems to be very "bomber". It's starting to rust and I need to spray it with a bit of paint when it warms up outside. I have a ridiculously long antenna that I bought at a truck stop attached to it.
Pic here.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 9th, 2007, 07:16 AM
why is the bumper bad for reception
Old January 9th, 2007, 08:48 AM
The only reason I could think of is the height... The higher the antenna the better the reception.
Old January 9th, 2007, 01:31 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Hmmm, I think it's becasue the bumper results in a poor ground plane. That is unless you have one built into the coaxial. Boat's and most RV's have this feature becasue they're made of fiberglass.
This article explains it in a bit more detail.
Old January 9th, 2007, 02:27 PM
Chaucer
Will
93 110 | 97 90
I like the antenna mount on ECR's project here: http://www.eastcoastrover.com/164.html
Old January 9th, 2007, 10:27 PM
jdempsey
Jason Dempsey
94/ D90/ Red
Cool CB Antenna
http://www.defendersource.com/forum/...tid=7841&stc=1
See the picture here:
I used an "L" shaped bracket that bolted onto my rear bumper. I grounded it by putting a screw threw the bracket and ran the cable under the chasis and into my tuffy box. The CB is in the tuffy box. its great b/c I can lock it without worry. The whip antenna connects to the roll bar on the outside of the driver side window. I likes it.
Persistence, there is no substitute
Old January 10th, 2007, 08:08 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Thanks for all your replys.
Looks like I am going to see how the "glass mount" antenna works first since it does not require much work and does not require drilling thru the body http://www.walcottcb.com/product_inf...roducts_id=843
If it does not work well I may mount thru the back with one of these http://www.walcottcb.com/firestik-lg...kit-p-974.html
or fab a bracket and attach to the rear door hinge.
Thanks.
Paul
Old January 11th, 2007, 11:47 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Here is a pic of my dual-band ham radio antenna. The radio is all nice and locked up in the tuffy center box. The antenna mount is on a thin piece of scrap metal and then u-bolted to the 3rd brake light tube. Finally, it's grounded to a ground in the brake light housing. It's very simple, looks good, and I'm sure something like it could be adapted to a CB antenna. Plus it gets the antenna fairly high which is good for line of sight transmissions.
1997, 1997 d90, 90, 97, 97 d90, d90, mount
CB Antenna Mounting nycjdp Defender Technical Discussions 36 March 6th, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
1997 D90 SW - Alpine White Troys For Sale - Vehicles 4 September 21st, 2005 08:40 PM
1997 D90 SW for sale J4hand For Sale - Vehicles 10 January 5th, 2005 10:15 PM
Trade my 1997 D90 for disco + cash dave_lucas For Sale - Vehicles 21 March 31st, 2004 12:51 PM
