Motor Mounts: 200TDI Transplant in 110 - Page 3 - Defender Source
Old July 3rd, 2016, 09:26 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I'll order these the second they are available.
Robert if we got a group buy together and sold a bunch could this make it close to the front of the list?
Old July 3rd, 2016, 01:40 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Count me in for a set. My back, ears and teeth will thank you.
Old July 12th, 2016, 02:23 PM
Naplm00
Matthew
So I may try the e39 540i engine mounts, they are about 5inches from tip of post to post and hydraulic. They support a fully dressed m52 that weighs in at about 390 lbs.
https://www.amazon.com/dp/B0196VS7KS...I1C2ZDRSPTPG3G
Old October 11th, 2016, 08:47 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
So my 200tdi is coming out and i would definitely be interested in the Mercedes motor mounts. Any leads? Part numbers?
Old October 13th, 2016, 12:33 PM
BlackField's Avatar
BlackField
Oscar
D110
These guys look similar and are pretty inexpensive:
https://smile.amazon.com/Engine-Moto...W124+W201+300E
Any reason why these wouldn't work?
Old October 13th, 2016, 12:52 PM
Naplm00
Matthew
They were about 3/4 of an inch to tall to fit the stock mounts
Old October 13th, 2016, 12:53 PM
Do they not also need to be installed horizontally only?
Old October 13th, 2016, 01:03 PM
BlackField's Avatar
BlackField
Oscar
D110
I will be making my own mounts, frame and engine side, for my 2.8 TGV. I read horizontal only somewhere on here also.
Old October 13th, 2016, 01:09 PM
I only mention it, because I'm not sure that Mr. Solis realizes this will require a complete custom fabrication of the complete mounting system.
Old October 13th, 2016, 01:29 PM
El Solis's Avatar
El Solis
Chris Solis
Thanks John! Yeah I knew it wouldn't be drop in as nothing on my truck is I figured since it the engine was out I'd investigate all possible options, suck it up and cry once situation.
Old October 14th, 2016, 08:29 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
any word on this?
and if forced to go with stock, are the genuine any softer that the other?
I actually read the aftermarket are softer on a UK site
Old October 22nd, 2016, 08:35 PM
andrewgodley's Avatar
andrewgodley
Andrew Godley
I replaced all 4 mounts (2 engine, 2 tranny) with Bearmach mounts. They can be squeezed by hand and are obviously softer. The vibrations from my 200tdi went away almost completely. It has made a huge difference. The vibes before would shake the dash, hood, and generally the whole truck. I hated it. Now it feels like a brand new car. It's so smooth. Highly recommend the bearmach mounts. Same size as the hard mounts that were on previously. The original mounts were hard as rocks. Don't know the manufacturer of them but they were terribly hard.
If there were even softer or more effective mounts I would try them, like these apparently mythical Mercedes hydraulic mounts. Reducing the vibes has made such a huge improvement to the driving enjoyment. If it was smoother it would be like a luxury car and not a defender but I really enjoy the more quiet cabin and would swap my already softer rubber for the hydraulic filled stuff if it made a difference. Until then, install the Bearmach rubber. HUGE improvement.
Cheers.
Old October 22nd, 2016, 08:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Old October 26th, 2016, 08:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by andrewgodley View Post
I replaced all 4 mounts (2 engine, 2 tranny) with Bearmach mounts. They can be squeezed by hand and are obviously softer. The vibrations from my 200tdi went away almost completely. It has made a huge difference. The vibes before would shake the dash, hood, and generally the whole truck. I hated it. Now it feels like a brand new car. It's so smooth. Highly recommend the bearmach mounts. Same size as the hard mounts that were on previously. The original mounts were hard as rocks. Don't know the manufacturer of them but they were terribly hard. If there were even softer or more effective mounts I would try them, like these apparently mythical Mercedes hydraulic mounts. Reducing the vibes has made such a huge improvement to the driving enjoyment. If it was smoother it would be like a luxury car and not a defender but I really enjoy the more quiet cabin and would swap my already softer rubber for the hydraulic filled stuff if it made a difference. Until then, install the Bearmach rubber. HUGE improvement. Cheers.
These Bearmach's have been the go to for years by these guys.
http://www.glencoyne.co.uk/tdiguide.htm
There's plenty of misinformation swirling around re 200 mounts. Nice to hear some real life experience. I mistakenly bought cheap aftermarket mounts and learned the hard way. Then I bought princely genuine mounts. They made a little difference but there's plenty room for improvement. Bearmach's sounds like the real ticket.
Old October 26th, 2016, 08:49 AM
AdamSanta85
91' D90 200TDI
The funny part is the Bearmach's are cheap mounts. I paid $5 a piece for them. Such a PITA install. I only managed to get 1 of the 4 in (the "easy" RH engine mount), and gave up for another day.
Old October 26th, 2016, 08:56 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Do you have a floor jack? The rear mounts in particular take like 10 minutes.
Old October 26th, 2016, 09:04 AM
AdamSanta85
91' D90 200TDI
The transmission mounts? How?
You have to take off the lower center bolt, easy, then there are 4 bolts per mount on the upper to get it off the transmission so that you can change the mount out off the car. When I jack the tranny up it hits the tunnel before going high enough to get a wrench in to get 1 or 2 of the 4 bolts off. So then you have to drop the metal chassis bracket. That is where I gave up for another day. I spent probably 1.5 hours to get to that point.
The LH mount on a LHD same thing. I was having a really really hard time jacking the engine up high enough to be able to get the mount out.
The RH side jacking it up after removing the intercooler piping and fan guard was doable but still a seriously tight fit. Getting access to the mount on that side was the easy part, but getting the engine up high enough to allow removal was tough.
Learn me. Please.
Old October 26th, 2016, 09:11 AM
There should be enough room to jack and remove all four mounts without removing anything on the chassis side. Do you have a mismatch of engine/gearbox and transmission tunnel?
Old October 26th, 2016, 09:14 AM
AdamSanta85
91' D90 200TDI
No
I would love for someone to show me how to get 1 of the 4 tranny mount upper bolts out (per side). There isn't room to get anything in there. I have all sorts of wrenches and sockets and swivels. IIRC 2 or 3 of the bolts are doable (and I had them loose), but there is 1 per side that just wasn't happening. I wish I had a picture.
Old October 26th, 2016, 09:27 AM
Maybe take a picture. I had my t. case out a few months ago and can't recall any problems with the mount bolts. I'll try and remember to look later.
110, 200tdi, motor, mount, tdi
ROW 110 200tdi implant 1of40 For Sale - Vehicles 12 October 17th, 2012 01:35 PM
1983 110 import report - Long grnrvrs Defender Technical Discussions 28 October 22nd, 2010 10:52 AM
Best way across the US Mike Hippert Defender Technical Discussions 173 April 29th, 2010 03:56 PM
84 110 200tdi pickup $10k Not Mine bitz The Flea Market 13 February 18th, 2010 12:42 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 07:27 PM
