Motor Hot at Idle - Page 2 - Defender Source
Old April 13th, 2012, 10:25 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by rover4x4 View Post
Please don't buy those cheap ass made in china water pumps, this is a good part to pay a full price on.
What about one of the mid level ones on BP's site? - Looks like there is a difference at least between the mid and low level propellers: http://bputah.com/RRC%20Parts%202/La...mp_STC483.html
Quinton Hazell looks like they have some shit together:
------ Follow up post added April 13th, 2012 10:28 AM ------
Originally Posted by rijosho View Post
Don, Dan posted a thread last year of his crazy new radiator.
------ Follow up post added April 12th, 2012 10:45 AM ------
Found it.
http://www.defendersource.com/forum/...eferrerid=1743
Thanks Josh - I might see what the local shop offers first and hopefully it will pass like Jeff Huff's radiator did.
but not too tight or you'll experience a premature bearing failure ... ask me how I know ... also when you remove it ... make sure you record what hole each bolt goes in otherwise it's a bitch to figure out where they go ... ask me how I know ....
Haha, good tip that I've heard before but knowing me would never have remembered as I was taking things apart. Will probably dive into this next week or the week after and we re-read while doing it to remember the steps and tips.
Old April 13th, 2012, 12:54 PM
Do your water hoses remain pressurized after you stop the truck? If not expansion bOttle cap my be at fault. It's worth getting a new one as they are cheap.
With all these mods ... You might as well upgrade to a 300tdi as you have the bonnet open!! ;-)
idle, motor
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
Very high idle, sorta, just appeared yesterday Hans Defender Technical Discussions 3 December 6th, 2004 08:16 PM
