Most hated bolt? - Defender Source
Old February 23rd, 2012, 08:18 PM
Most hated bolt?
Did the rotors shocks and LH swivel on the SWB RRC. Must place the top swivel pin bolt thats under the brake pipe holder weldment thingy in my top ten Most Hated Bolts category.
Old February 23rd, 2012, 08:23 PM
Bulkhead long bolt is #1 for me.
The the nut on the a-frame
Then the stupid screws that go through the floorboards to the brackets on the bulkhead.
Door hinge screws.
etc.
Old February 23rd, 2012, 08:42 PM
The ones you have to line up (and can't see worth a crap) really suck - like the two on the rotors - can never seem to line those things up! How about the one on top of the starter?
But then there's the ones that are soooooooo tiny that any tool that fits the head is so thin that it breaks! Example - the little allen head screws that go into the ferrule nuts on the wipers. Yeah, it's not a technical one, but I bent one allen wrench, and broke the torque one. Time for heat I guess.
Old February 23rd, 2012, 08:47 PM
bossman429's Avatar
bossman429
Adrian
1988 90
You've never done headers on a 2v 4.6L mustang (94-04)
My top 16 most hated bolts are every single one of those. I just pull the engine now when I have to do them.
Old February 23rd, 2012, 11:46 PM
One of the hoses on the PS pump fought me tooth and nail once that was pretty awful. The adjustment on the steering box is a pita, the exhaust manifold bolts have caused me heartburn also
Old February 23rd, 2012, 11:49 PM
d1 bellhousing bolts
Old February 23rd, 2012, 11:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The 16 bolts & nuts on the drive shaft flanges, they're something weird other than SAE & metric. Won't be bad to replace except they're trapped on the front output of the LT230Q.
Old February 24th, 2012, 02:28 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
I hate the ones that brake! Or get dull so you have to drill them out! Rusty piece of shit bolts
Old February 24th, 2012, 02:47 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Front bumper mounting bolts when using an ARB bumper without captive nut plates.
Driver's side engine mount, top nut.
Slightly swelled alloy lug nuts that don't want to come out of the socket.
Every #3 philips on the truck.
Panhard Rod bolt at the axle end.
X2 on the floor panel ones.
X1mil on the front bulkhead to outrigger bolts.
Old February 24th, 2012, 06:19 AM
Swelled alloy nuts at the top of my list. Everything else I'll take a torch to.
Old February 24th, 2012, 06:41 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'd have to say the NAS 110 cage exterior bolts suck especially where the cage meets the body - everything is under tension and nothing lines up.
Semper Fi!
Old February 24th, 2012, 07:03 AM
Funny how some of these are no problem really compared to the two bolts that hold the front end of the door sill channel to the foot of the bulkhead. you can barely get a wrench on them and when they're siezed you can't get a grinder on them. maybe a dremel though never tried it. Usually at that point the bulkhead foot comes off anyway.
BTW, driveshaft bolts *should* be 9/16 UNF, I believe even on the later metric vehicles. On my 90 the door hinge bolts and front floor to footwell screws are all stainless thanks to the PO. I left those screws out on the 109 since the holes were all buggered up. Door hinge bolts I guess I've just been lucky. Not so much of a problem with the superior II/IIa hinges.
Old February 24th, 2012, 08:13 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Driveshaft bolts - buy that extended socket from RN, AB, etc. I throw that on to the end of the cordless impact and they come off pretty easy. Bonus - I believe they are the same nuts as the diffs.
Biggest PITA bolts for me so far: the NAS rear bumper/gas tank skid. I spent 3 days getting them drilled out and retapped as they were rusted and seized and snapped every one. I drench them with copper grease every time it comes out now. At least the access was good.
Also - one of the rear A arm bolt was siezed and was a bish to get out. I have a 30mm (I think that is the size) spanner and it fits nicely for the ball joint bolt.
Old February 24th, 2012, 09:07 AM
LRover's Avatar
LRover
J. Michael McCaig
I hate the top allen-socket bolt for the starter on a V8. Can be a real pain when it's frozen, especially when someone else has rounded it out...
Old February 24th, 2012, 11:16 AM
The ones going into the cross member from the nas bumper suck.
Old February 24th, 2012, 11:20 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
It may be easier to list the bolts that are not a pita. I would make for a short thread.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old February 24th, 2012, 11:25 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
-Philips screw that is made out of cheese that hold the drum brake on.
-8mm allen bolt for the starter... its the only allen bolt on the truck and its in prefect position to fill up with mud.
-A-frame nut.
-Ignition switch screws. You need an eye glasses screwdriver for those.
-Any bolt or nut you find that was welded on by the previous idiot owner.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 24th, 2012, 11:31 AM
Originally Posted by ini88 View Post
--Ignition switch screws. You need an eye glasses screwdriver for those.
Ah forgot about that one! The worst part was that the manual only lists the screw that faces you, not the one on the other side that you can't see!
Old February 24th, 2012, 11:42 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
The rusted upper front shock bolt gave me a hard time. I ended up getting my sawzall out and cutting the shock in half
Old February 24th, 2012, 11:53 AM
Oil gallery plug on the side of a jag 5.0l motor.
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
