more tire questions - Defender Source
Old October 27th, 2003, 11:02 PM
more tire questions
okay so trying to figure out tires.. it what ways would a 265/75/26 be different than a 235 or 245/85/16. would the later just be taller and more skinny? I am thinking taller and skinny for my next set of tires. anyone ever bought tires from the UK and had em shipped over. got my eye on some michelins not XZL's
Old October 28th, 2003, 08:30 AM
265/75/16. 265 is the width in milimeters, 75 is the % of the width that represents the side wall height and 16 is the rim height. so 265 * 75% = 198.75. 265/25.4=10.4 inches for width.
198.75*25.4=7.82 inches for tire height 7.84*2+16=31.6 inches tall for tire height. This may vary a little as tires are not exactly the size they say they are.
Old October 28th, 2003, 10:56 AM
thanks.. so the 235/85 should be the same hieght just a little narrower??
Old October 28th, 2003, 11:06 AM
exmodlad
Guest
Posts: n/a
Philip:
in case your looking here in North America....a 7.50R x 16 tire is almost the same size as a 235/85/16
i see that Rovers Down South has the Goodyear G90's ...i have these on my truck and they are great tires....quiet on pavement and good offroad
Gord
Old October 28th, 2003, 11:11 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I currently run 255/85 tires. I think this is a great comprimise, because it's taller than stock, and only a little bit narrower. It really looks great, yet increases your cleance.
It's about a 33" tire, so a slight lift (OME, etc) is probably called for, although I'm not sure if its required.
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
Tire, coolant and other new owner questions DaveHuny Defender Technical Discussions 2 October 24th, 2004 03:27 PM
