More MAR aftermath - Defender Source
Old October 5th, 2015, 02:36 PM
More MAR aftermath
So on the way home what seems to be the rear end is vibrating pretty good, it lessens some when i put the clutch in..
symptoms: pretty good harmonic shaking when decelerating from any speed over say 35 mph..
it does shake a lesser amount when accelerating but not as bad..
Driveshaft loose? Clutch going (slipping? doesn't feel like it..) something else loose back there.
My steering wheel does not shake so its not death wobble or maybe it is.
also getting a CEL 45 again (started on the fire roads before the alt went) that is now constant. Only Code 45 is present when i run through them, I did find that my o2 sensor was loose on that side however tightening it up and switching to a backup did not change the issue. I'm going to retime it tonight if needed. which fixed this they last time. and check the exhaust bolts on that side.
The good news is the Alternator works perfect, and i have a 140 amp one on order
ah the joys of rover-ing
its a 95 D90 NAS for guesses
95' D90 - daily driver..
Old October 5th, 2015, 03:08 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
No idea on your new noise but I got a good picture of your alt install!
Rent my
Old October 5th, 2015, 03:15 PM
Time to start checking for loose nuts and bolts from the wheels, driveshafts to transfer box etc.
Doubt its a suspension related issue, but check those anyway.
Old October 5th, 2015, 03:16 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Running wheel spacers?
Old October 5th, 2015, 03:23 PM
No spacers, checking wheel bolts as we speak
------ Follow up post added October 5th, 2015 12:26 PM ------
No idea on your new noise but I got a good picture of your alt install! .
awesome thanks
Old October 5th, 2015, 03:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Rob, also check the back side of your wheels.
You're running the boosts right?
Sometimes even when the front looks pretty clean some mud or clay will stick to the back side and throw off the balance significantly.
Rent my
Old October 5th, 2015, 04:33 PM
Already done checked back sides of them, test driving now retimed ignition.. Found a semi loose tcase mount but still there. Pronounced when accelerating or more so when decelerating
Old October 5th, 2015, 04:40 PM
Bad U-joint in rear prop shaft. Worn bearing on t-case output or diff? Shake everything hard and see if anything has any play.
Or built up mud in a wheel. ;-)
Old October 5th, 2015, 04:50 PM
Mud in the wheels was my go to.. I'm probably going to need to pull them and double check.. But that would make it vibrate coasting too (it does but not nearly pronounced as it does in gear which has me worried
Old October 5th, 2015, 05:12 PM
Think I found it.. Rear u joint looks like it has 1/4" of movement in it.. That would explain the driveline vibration under load I think... Easy to replace? The whole rear shaft has some play as well.
Old October 5th, 2015, 05:50 PM
Related question, while I wait for a u joint (unless I can buy one locally) can I remove the drive shaft and run in front wheel drive? Diff locked?
Old October 5th, 2015, 05:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes, but will promote tire wear on the front wheels.
UJ is a universal size shared with many other marques.
RDavisinVA
Old October 5th, 2015, 06:35 PM
Thanks Robert picked up a spicer one locally (or at least made by spicer supposedly.
Looks like an easy install
Drop rear of axle, remove and replace, fill with grease, reinstall axle bolts on rear. Am I missing anything?
Old October 5th, 2015, 07:22 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by rlynch356 View Post
Thanks Robert picked up a spicer one locally (or at least made by spicer supposedly. Looks like an easy install Drop rear of axle, remove and replace, fill with grease, reinstall axle bolts on rear. Am I missing anything?
there are some good youtubes re replacing UJ's.
Old October 5th, 2015, 07:34 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
If one end is gone the other is soon to follow, you say the whole prop shaft has play? Is there any up and down play in the sliding coupling?if that is loose as well, get a new prop shaft.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 5th, 2015, 07:48 PM
1of40's Avatar
1of40
1of40
very good point. i think I made this mistake just recently. I hate removing and replacing ds' too.
Old October 5th, 2015, 07:58 PM
no problem driving on the front if the rear DS is out or vice versa. It won't affect tires at all.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 5th, 2015, 08:36 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah, don't get tire comment either-- no big deal to run without drive shaft. Also, uj's are super easy to replace and frankly just replace worn one. I know which ones I've replaced and which ones I haven't and I have one that is amazing (3 to one, rear on front drive shat). They don't wear equally not do you grease them equally. Some caps plug and don't get fresh grease and wear diffrrently. I replace what needs replacing...
Old October 5th, 2015, 09:02 PM
Chris, if one doesn't take grease, tap the opposite yoke with a hammer to push the spider over and make more room for the grease to get through.
Present:
1987 RRC- "Chewy 2"
Past:
Old October 5th, 2015, 09:06 PM
Thanks all - I just got one.. so will report back - i may have to outsource the job (along with chasing the CEL 45) as its my DD and this week is packed with after work Kiddo stuff..
Drive shaft does not seem to have up/down play - just rotational play if that makes sense - front has the same slop.
I'm probably going to need to gets some wood(s)
Mid-Atlantic Rally (MAR) 1999 - Virginia USA chrisvonc Trip & Trail Reports 0 June 18th, 2004 08:51 AM
Mid-Atlantic Rally (MAR) 2003 - Virginia USA chrisvonc Trip & Trail Reports 0 June 15th, 2004 02:34 PM
Rausch Creek, Mar 26-28 loykd Trips, Trails and Events 125 March 31st, 2004 07:54 PM
MAR 2003 photos KeithElisa Misc. Chit-Chat 3 October 14th, 2003 08:16 AM
MAR Orphans loykd Trips, Trails and Events 60 October 7th, 2003 10:58 AM
