More legroom - Defender Source
Old August 4th, 2005, 07:56 AM
JohnK
John K
More legroom
I am 6'4" tall and a little cramped behind the wheel of a D-90. I have heard there are ways to change the seat to gain legroom. The only solution I could find searching the forum is the MUD-UK Seat Rails. Does anyone have experience with this or any other solution? Is there a difference between the SW and ST. Thanks.
https://www.expeditionexchange.com/muduk/
Old August 4th, 2005, 08:09 AM
You can make them yourself
http://www.defendersource.com/mod/seat_riser/index.html
Old August 4th, 2005, 08:55 AM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
John,
I have the Mud seat rails. THey are very high quality and easy to install, only took my 30 minutes. They only problem is they raise you a full inch in height. If you are very tall, you may hit your head on the roof top.
Matt...
Old August 4th, 2005, 09:00 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I'm 6'8" and don't seem to fit into anything too well, so I think I'm more used to tolerating the discomfort of the 90 than many. I haven't changed my seat-- I'm just happy that the top of my head doesn't rub on the roof and my head doesn't bonk the roll bar. I must say that using the clutch while the left turn signal is on can be a challenge!
Old August 4th, 2005, 09:35 AM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I'm 6'6" and have the same problem with the turn signal. suck it up.
1995 D90 ST
1999 Super V8
Old August 4th, 2005, 12:51 PM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
i thought i was the only tall peson that would subject himself to a cramped d-90. at 6'7" i found the risers to be very nice. my leg only rubs the tuffy stereo box. i would not have bought a set of risers but a friend of mine had a spare set from when he made his which he gave me for free. they def. help.
Mastercraft Rubicon Seats Shearpin Misc. Chit-Chat 10 December 20th, 2007 11:03 AM
D110 Second Row Seat Suggestions mattarm Defender Technical Discussions 11 September 25th, 2006 09:55 AM
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
