More electrical problems - Defender Source
Old February 10th, 2010, 01:02 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Here we go again. After coming in from the snow I had one dim brake light. Pulled into the garage and turned it off and replaced both bulbs and greased socket. Now it won't start, can't move shifter(97) no brake lights or turn signals. Also no rear wiper. Checked all fuses seem fine. This is becoming agravating!
I do hear the fuel pump come on when I turn the key. Doesn't even trn over.
Any ideas before I had it towed again. Not sure how I'm going to do that since I can't get it out of park
Old February 10th, 2010, 01:15 PM
minorthreat
Lance
1997 LE, 1997 Black ST
Just check your fuses again. I assuming you're checking the fuses under the center console ? I think it is one of the 7 amp fuses. Weird, but it has happened to me, too.
Old February 10th, 2010, 01:26 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks..I will recheck them. Did you have all the things I listed not working as well.
I do notice that when I hit the brake i don't hear the shifter relay click like I'm used to.
Old February 10th, 2010, 01:29 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
What's the voltage?
My oil line fix
My 100k stopped odometer fix
Old February 10th, 2010, 01:33 PM
Campbell's Avatar
Campbell
Rich Campbell
Hans,
what do you mean?
Old February 10th, 2010, 01:35 PM
Haston
Christopher Petite
Sounds to me like a faulty brake light switch.
May be worth investigating, as failure always locks the shifter in park.
Old February 10th, 2010, 01:42 PM
Campbell's Avatar
Campbell
Rich Campbell
I will check that as well. Would it cause the turn signals and rear wiper to stop as well?
Old February 10th, 2010, 01:54 PM
Hans's Avatar
Hans
Hans Haase
Sorry, baby was grabbing my leg as I tried to do the last one. Makes me cut down on the time I spend posting
Just wondering if maybe you were having a system voltage issue in there somewhere. With just a dummy light, sometimes you can have a weak alternator or battery, without any dash indications. The more I read though, the less I'm thinking this will be the issue.
-Hans
My oil line fix
Old February 10th, 2010, 05:04 PM
Campbell's Avatar
Campbell
Rich Campbell
Found bad fuse with light test. Everything is working except one tail light. Changed bulb and housing and it is still very dim....any ideas. It was strange because I got evrything working and went for a drive in the snow. Came back at one tail light is out. These electrics never stop amazing me.
At least it starts.
Thanks guys
Old February 10th, 2010, 09:23 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
One good upgrade to do is to change all fuses by the
ones that have a built-in small bulb that goes on if the
fuse blow.
Spare you to check them one by one each time you
have an electrical fault, which is pretty often for almost
all of us.
- Charles Eames
Old February 10th, 2010, 09:49 PM
huck1974's Avatar
huck1974
shane cates
94 d90
ground
And hay
And I love you too
Old February 10th, 2010, 10:15 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bottom of page:
http://www.electronics123.com/s.nl/sc.11/category.16/.f
- Charles Eames
Old February 10th, 2010, 10:41 PM
jack SF
jack baran
95 ST yellow
what kind of grease did you use? is your grease conductive and shorting out the whole system? check that first.
and than check a ground on right side of transfer box.
Old February 11th, 2010, 07:22 AM
Campbell's Avatar
Campbell
Rich Campbell
Bulb grease.
Thanks for all the great advice. I think I will send it to my mechanic.
Is there a way to replace only the back wiring harness. Last time I had this problem some wires inside the frame rails were bare. Thinking about pulling all the wires out of the rail so I can inspect all of them or just replacing the rear harness from the engine back leaving it outside the frame.....is this possible.
Thanks again.
Old February 11th, 2010, 04:24 PM
Campbell's Avatar
Campbell
Rich Campbell
Well...I replaced all the bulbs and checked all the connections on the whole truck. I got everything to work! Then I took it for a drive. When I got back the passanger brake light was dim and flickering...as well as the front passanger running light. The 5amp fuse, second one in from passanger side and bottom row did blow prior to me fixing. Any ideas where this might be shorting out based on what is dim?
Thanks as always
Bulb grease.
Thanks again.
------ Follow up post added February 11th, 2010 10:54 PM ------
This is insane. I think I have narrowed it down some more. I noticed the lights were flickering almost like to music. I pulled the fuse for the radio and replaced the 5amp fuse I mentioned above...and it seems fixed...WTF
I don't have a working radio but at least it seems all my lights are working.. I haven't done anything different or worked on the radio for a long time. Has this ever happened to anyone..
Old February 11th, 2010, 11:56 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It sounds like a ground to me, but I couldn't tell you where.
------ Follow up post added February 11th, 2010 10:57 PM ------
...something in the illumination circuit to the radio maybe?
Old February 12th, 2010, 08:10 AM
Campbell's Avatar
Campbell
Rich Campbell
Electrics
Thanks..
An illumination ground. That sounds like a great place to start. I have all the radio fuses out and everything is working except the radio. Odd thing is the stock radio is still lit up to some degree when I turn on the lights. Does this mean anything to anyone?
Old February 12th, 2010, 09:11 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, the radio should have a wire that is hot with the parking lights, to dim the display on the radio at night. If the D90 is like a BMW, one front and one rear tail light are wired to one fuse and the other two through a second, so that if one blows, you still have some marker lights on. I'll bet the radio wire is connected to the same circuit you are having a problem with. It sounds like that circuit is grounding through the radio somehow. I would trace that wire, and also check for continuity between that wire and the case of the radio to see if it has shorted internally. Just my $.02, but that is where I would begin.
Old February 12th, 2010, 09:22 AM
Campbell's Avatar
Campbell
Rich Campbell
Awesome...Thanks......Maybe I could just cut the wire that is hot with the parking lights. It isn't that important to me to have the radio lit up with the parking brake......now to just try to find out which wire it is.
Old April 12th, 2010, 02:42 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Richard, did you ever find your fix? My 97SW is giving me signs of bad things to come. My rear wiper just quit working, then radio went and today my gas gage won't move off E.
electrical, problems
Electrical Problems Galore- Coil, MAF Sensor, Wipers, Fuel Pump, Short Heath Defender Technical Discussions 10 August 28th, 2008 05:52 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Rear Door Electrical problems, what first? Hammertime Defender Technical Discussions 2 August 5th, 2007 01:01 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
reciever electrical problems yellowrover Defender Technical Discussions 7 March 17th, 2004 05:13 PM
