More electrical problems - Page 2 - Defender Source
Old April 13th, 2010, 09:10 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Yes,
It turned out to be some worn wires on my main harness inside the frame rail. If I were you I would check where the wires go in toward the front and where they come out at the rear crossmember on the pass side. Maybe they are just scuffed up and hitting the metal of the frame. I had my entire harness pulled out from the frame. A few large sections were replaced and tapped up. I chose to waterproof it and zip tie it up to the frame rather then putting it back inside.
So far all good.
Hope this helps.
electrical, problems
Electrical Problems Galore- Coil, MAF Sensor, Wipers, Fuel Pump, Short Heath Defender Technical Discussions 10 August 28th, 2008 05:52 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Rear Door Electrical problems, what first? Hammertime Defender Technical Discussions 2 August 5th, 2007 01:01 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
reciever electrical problems yellowrover Defender Technical Discussions 7 March 17th, 2004 05:13 PM
