More Bellhousing Woes - Defender Source
Old March 9th, 2009, 02:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Allen Bolts are not recessed? I might have the wrong ones?
And for some reason, the three bottom stud holes are not tapped. Any ideas?
Red 4 Allen, would work if they were flush?
Yellow-line up with the holes in the bellhousing, but are not threaded? For Studs.
ID:	18208   Click image for larger version
Old March 9th, 2009, 03:32 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yes, I believe the un-threaded ones are for alignment studs. Most transmission mounts have a few, they make installation a hell of a lot easier.
As to the rest, don't forget the thickness of the bellhousing and washers. I'd measure the gap that you're seeing, and them measure the thickness of anything else that is going to go in there. You may be fine as-is. The bellhousing has pretty thick walls to it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 9th, 2009, 04:19 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
i think i figured it out. Defender 200ti engine, Disco flywheel housing, defender lt77s
any Ideas where a 200 with a 10D serial number came from?
Old March 10th, 2009, 05:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Sunk the 4 allen bolts, threaded the holes for the studs, its all good.
10D serial number anyone?
Does anyone have a pic of how the serial number should be stamped on the block? Mine looks fishy.
If anyone tells you importing a 2nd hand engine from the UK isn't an adventure, they're a liar.
Old March 10th, 2009, 05:51 PM
Can't see anything anywhere on that engine code.
How about a picture of the engine and the serial number?
Old March 10th, 2009, 07:45 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
i'll try tomorrow, but it might not show up that well
Clutch woes... Trigger Defender Technical Discussions 8 September 9th, 2010 07:01 PM
Stainless nuts on a Aluminium bellhousing tomaco1 Defender Technical Discussions 21 January 11th, 2010 12:44 AM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
The woes of a nightmare repair job Hans Misc. Chit-Chat 13 January 26th, 2005 04:15 PM
CDL woes ToaDisco Defender Technical Discussions 10 September 27th, 2004 06:10 PM
