Molasses for rust removal - Defender Source
Old February 23rd, 2015, 12:43 AM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Hey guys, so we all know how rust is a word synonymous with many land rovers. Well recently I hear that a molasses bath works to remove rust. Has anyone else heard of this rust removal solution? Any info would be great.
Old February 23rd, 2015, 01:39 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
It will surely bring ants.
Black Rhino Lives Matter
Old February 23rd, 2015, 01:52 AM
RBBailey
RBBailey
1965 IIa
Maybe ant eat rust?
Old February 23rd, 2015, 01:56 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
There's always a used motor oil bath. Should only take about 5 years soaking or so.
But in all seriousness, if molasses works, go for it! I'd be interested in just knowing.
Old February 23rd, 2015, 02:09 AM
Landyman1's Avatar
Landyman1
Landyman
I'll try it out in the sometime this month when I have the time. I'll use a rusty Ford Model T piston I found in a barn, so that should bring out the truth. In truth, this experiment will probably be slow as well.... Molasses
Old February 23rd, 2015, 07:11 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Curious what you need to derust? Small parts? Don't say chassis.
Old February 23rd, 2015, 07:17 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Vinegar works, coca-cola work as well, all acid food should work. Just depends on how long can you wait and how much it will cost!
Old February 23rd, 2015, 07:52 AM
Don't waste your effort. Just get some phosphoric acid from your local chemical supply. Make up a solution in a bucket and get r dun
Old February 24th, 2015, 05:40 PM
2x phosphoric. even at a concentration of 10% it has not failed to derust even the disgusting look rusted parts. just don't leave it in too long because it will dissolve bare metal (albeit at a much slower rate than hcl.)
Old February 24th, 2015, 07:07 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
This guy did it...and then he gave up and just took the thing to get sandblasted. Save yourself the trouble and blast.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old February 24th, 2015, 08:17 PM
cbfritz_03
Carmen
none
Yes, it works. I've been playing around with all the different ways to remove rust. Molasses, vinegars, sodas and electrolysis. They all work really well. I've been able to save just about every nut and bolt on my truck; meaning I didn't just grind them all off to be fast. I mentioned to a friend of mine that I was trying to decide how to clean them and he suggested tumbling. He's a car restore person too. Yes, I'm being uber geeky on it and want to reuse and save as many of the original parts as possible.
Old February 24th, 2015, 10:37 PM
Landyman1's Avatar
Landyman1
Landyman
just wondering, do you know the chemical processes involved and how molasses removes rust. Any info is appreciated! Thanks
Old February 24th, 2015, 11:13 PM
cbfritz_03
Carmen
none
Here you go. On another forum people mentioned that ketchup and cola will even work. From my experience the shape of the item, the severity of the rust, the temperature and dilution of whatever mixture you are using determines the amount of time it needs to soak.
Why does molasses remove rust
Old February 25th, 2015, 08:14 AM
Landyman1's Avatar
Landyman1
Landyman
Here you go. On another forum people mentioned that ketchup and cola will even work. From my experience the shape of the item, the severity of the rust, the temperature and dilution of whatever mixture you are using determines the amount of time it needs to soak. Why does molasses remove rust
thanks for the link!
D-90 Restoration / Rust Removal Flagg Defender Technical Discussions 20 March 14th, 2012 10:11 PM
Rust removal, new way artm Defender Technical Discussions 10 April 14th, 2010 09:55 PM
To rust, or not to rust ? RBees Misc. Chit-Chat 10 May 8th, 2008 10:40 AM
