Modifing a 110 exhaust to use on a 90? - Defender Source
Old December 16th, 2013, 12:35 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Anyone ever modify a 110 exhuast to be used on a 90. I'm thinking of cutting down the NRP exhaust I have in the forsale secton to use for my 300tdi swap. I'm guessing it's longer under the rear seat section and where it extends out the back. Any thoughts on this, anyone have any underside pictures of a 110 exhaust mounted at the back corner?
Thx,
Old December 16th, 2013, 01:34 PM
psykokid
Jake
1997 Disco
Might be worth it just to check the routing. It will have to be shortened between where the pipe leaves the mid muffler to the tail rear muffler. Also, doesnt the exhaust on the TDI's go pretty much straight back from the turbo downpipe whereas the V8 muffler goes towards the center where the Y-Pipe is and then doglegs out towards the left side of the frame and then back?
Since you already have it and it doesn't seem to be selling you might as well mod it to fit, you're out only what it costs to make whatever changes. You might be able to look at the straight sections of pipe and just cut it and lego it to fit. Anything would be better than the stock normally aspirated diesel exhaust you have in there now. Less back pressure is always good with turbo motors..
Old December 16th, 2013, 01:40 PM
ECR says the gas NRP mufflers is too restrictive and kills diesels.
Old December 16th, 2013, 02:06 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
This is correct - with the 300 all you want to do is get the hot gasses out as quickly and easily as possible...
Old December 16th, 2013, 02:28 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
All good points, was only thinking of using the portion from the muffler towards the back of the truck anyway. As I think about it, the 90 ones vary from the 110 right where they turn to avoid the fuel tank.
110, 90, exhaust, mod
50 Sets of New 90 and 110 complete headliners are on the way ExmoorTrimUSA The Vendors Loft 5 March 30th, 2013 01:04 AM
Galvanized Chassis 110 / 90 FS SafariHP The Vendors Loft 0 January 27th, 2011 05:42 AM
Axle swap 90 and 110 101 tomaco1 Defender Technical Discussions 6 November 22nd, 2010 08:27 PM
110 for sale(maybe) or my 90 mpsteil Misc. Chit-Chat 6 January 29th, 2009 10:43 PM
Trade 110 for 90 "FEELER" mpsteil Misc. Chit-Chat 14 August 23rd, 2008 07:50 PM
