MoD trailer light plug adapter? - Defender Source
Old March 31st, 2013, 06:54 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Here is a picture of the trailer light plug on my 1986 MoD Ninety. It has 12 connectors!
Where can I find an adapter so I can use a 'standard' U.S. flat 4 connector trailer plug?
Mike.
Old March 31st, 2013, 07:27 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
That's a NATO 12-pin recepticle. There are lots of pinout diagrams for these on net. Here's one that might mach up:
http://www.dscc.dla.mil/Downloads/Mi...21/ms75021.pdf
A simple check with a multimeter will tell you if that's correct.
What I would do is to figure out the pinout for your trailer's cable, then compare it to the NATO pinout. I would buy one of the male NATO cables and chop one end off. Then I would get waterproof heat shrink buttsplice connectors and splice it together with your trailer cable. As you know, military trucks have many lighting selections depending on the tactical situation. Pick the lines that match up with your normal nighttime lights setting. Again, the multimeter will help you here.
http://www.secamerica.com/products/cables/index.php
------ Follow up post added March 31st, 2013 05:30 PM ------
Also, check the voltage on the pins. They may be putting out 24V, which would need to be converted down to 12V.
Old March 31st, 2013, 09:30 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
I have a 12 pin end from a Sankey trailer that will plug into that receiver. I just pulled all the wiring out of the trailer and was going to throw it out but you are welcome to it. Just let me know as I'm in clean out mode.
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old March 31st, 2013, 10:47 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Yes Scott, that will help. I will PM my address.
Mike.
Cheers
ht, mod
Trailer Plug Problem AGAIN! The Wizard Defender Technical Discussions 14 June 12th, 2011 04:13 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
trailer light and defrost lite won't go out!? chidiesel Defender Technical Discussions 0 February 18th, 2004 03:39 PM
Trailer Light Connector loykd Defender Technical Discussions 3 November 17th, 2003 04:31 PM
