MOD Side Lights - Defender Source
Old January 14th, 2015, 06:12 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
MOD Side Lights
Could anyone tell me how to remove the whole light assembly? I would like to install a bezel so I would need to take em out.
Thanks!
Pablo C.
Old January 14th, 2015, 06:22 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
covers should spin off.
Old January 14th, 2015, 06:50 PM
PabloCocito
Pablo Cocito
They do, but I also need to remove the assembly.
Old January 14th, 2015, 07:12 PM
Don't be shy, dig in and report back.
Old January 14th, 2015, 07:25 PM
jafir's Avatar
jafir
Jafir Elkurd
Wow. Those look new. Where is the 1/2 inch thick layer of paint?
Old January 14th, 2015, 07:41 PM
They sure do look a lot nicer and straighter than the ones that came on our trucks.
Old January 14th, 2015, 08:10 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Their is 3 small bolts ( straight head ) with a very small nut on the inside of the fender, 6MM I think. You need to take out the headlight assembly to get access to the back of the housing and remove the nut. It's a bit of a pita as you can't see the inside but they look in good shape so hopefully they will come right off.
Please let me know if you decide to swap them out. I'm looking for a few for the next build.
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old January 14th, 2015, 11:02 PM
PabloCocito
Pablo Cocito
Originally Posted by roverx View Post
Their is 3 small bolts ( straight head ) with a very small nut on the inside of the fender, 6MM I think. You need to take out the headlight assembly to get access to the back of the housing and remove the nut. It's a bit of a pita as you can't see the inside but they look in good shape so hopefully they will come right off. Please let me know if you decide to swap them out. I'm looking for a few for the next build. Cheers Scott
Thanks! Will give it a shot tomorrow!
Old January 15th, 2015, 12:23 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I think I have a few sets in the shop - fronts, rears, or both?
I seem to remember that you screw off the lens cover, pull the bulb out, push the rubber bulb holder through (out toward the lens cover side), and three scores hold the threaded section to the truck.
Old January 15th, 2015, 04:08 PM
PabloCocito
Pablo Cocito
Got them out! Very simple after all. Pull the rubber boot out, and there's 3 screws behind that.
Thanks!
Old January 17th, 2015, 12:56 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Thanks!
Nice truck...
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old January 17th, 2015, 02:25 PM
PabloCocito
Pablo Cocito
Originally Posted by Ohlins View Post
Nice truck... .
Thanks! I'm loving the way it's starting to look, I've only done the front end so far, but lots more to come!
Old January 17th, 2015, 02:51 PM
Did you reuse the rubber boot and bulb holder or did you have to rewire stuff?
Old January 17th, 2015, 05:44 PM
PabloCocito
Pablo Cocito
All the stuff inside of the assembly was pretty much brand new, it al went back in
For sale Ex MOD lights Hache For Sale - Parts 6 April 15th, 2015 12:55 PM
Running Lights / Interior Lights Short Wolf Fabrication Defender Technical Discussions 21 February 17th, 2012 07:27 AM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
