Mobil 1 in the diff's - Defender Source
Old November 12th, 2003, 11:22 AM
okay so was gonna finish with the synthetics and the Mobil 1 syn is only availible in 75wght gear oil. I am not 100% sure if the book calls for 80 or 90? at any rate would it be okay to use the 75wght in the diffs and case or should i stick with what the book suggests?
Old November 12th, 2003, 11:51 AM
I use Mobile One 75wt in the Diffs for the last year with no problems, and I put it in the new T-case when I installed it before Laborday. I can shift the T-case without the 90 having to be rolling, infact it goes in and out very easy and never makes any noise. Oh and NO leaks either.
Old November 14th, 2003, 10:48 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
As much as I love synthetic oils I feel that I should at least mention that if you are intent on spending much time in water you might think twice about these oils in a diff... After one trip under water I check my oil after a season spending "some time" in water I just change it... Cheap insurance... Amortize the life of the syn oil VS. the cost of regular old 90wt and it's a pricey proposal... Good for a good meal anyway
Keith
Keith
Big, Red and ... aaa Red..
Mobil 1 in diffs? JBfoot Defender Technical Discussions 1 August 17th, 2008 02:35 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
Stock 24 Spline Diffs willtillery For Sale - Parts 0 September 6th, 2004 09:21 PM
D90 diffs stanman Wanted 4 May 19th, 2004 01:24 PM
what weight oil is best for diffs & x-fer case? JRowe Defender Technical Discussions 5 March 5th, 2004 09:04 PM
