Mmmmm x-lites! - Defender Source
Old January 11th, 2013, 12:09 PM
Mmmmm x-lites!
Just arrived ..
2 -spot / 2 - flood
Simple design. Understated. No garage clearance issues for ikea parking! ;-)
Old January 11th, 2013, 12:42 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Are these from X-Engineering or something?
Old January 11th, 2013, 12:43 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
No. They are from Home Depots lawn and garden section.
Jimmy Buffett
Old January 11th, 2013, 12:48 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Yes they are from X-eng. http://www.x-eng.co.uk/X-Lite.asp If they were LED they would be really cool but are pretty neat none the less.
Old January 11th, 2013, 12:59 PM
Because of the very simple design I can substitute led GU5.3 bulbs when I find some bright enough.
Old January 11th, 2013, 01:24 PM
psykokid
Jake
1997 Disco
Is there a lens in front of the bulb/reflector unit? Hard to tell from the pics.
We used to run this style of lamp in the lamp diffuser housing of a few big commercial photo printers i used to operate when I worked on the a lab side of things. Course the bulbs we were using were hi wattage AC bulbs, but same style with the bulb and reflector being integrated into a single unit..
Old January 11th, 2013, 01:37 PM
No lens ..
Basically a tube with a gu5.3 bulb and a circlip.
ID:	64352   Click image for larger version
ID:	64354   Click image for larger version
Old January 11th, 2013, 01:38 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If you do, get some with the CREE led bulb. They are bright.
- Charles Eames
Old January 11th, 2013, 01:39 PM
Do you have a set that you can just shine on your Boosts at all times?
Old January 11th, 2013, 01:40 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Let us know about your impressions once you have them mounted and see what kind of light they are putting out.
Old January 11th, 2013, 02:17 PM
psykokid
Jake
1997 Disco
No lens ..
Thanks, your pics illustrate what i was looking for. There is something protecting the bulb/reflector.. I was thinking it was possibly like a standard halogen with some sort of glass in the front versus just an open reflector/bulb like this:
Old January 11th, 2013, 02:39 PM
The gu5.3 is a sealed unit and the x-lite is really just a mount for the light. I'm not looking for a mega bright solution to illuminate the moon ... Just a reasonable amount of extra light discretely.
The difference between spot and flood appears to just be the bulb reflector type.
To use led's I need to find a sealed one ...
------ Follow up post added January 11th, 2013 02:40 PM ------
I just want to boost my light or light my boosts.
Old January 11th, 2013, 03:01 PM
Those look like the lights I had for my mountain bike a decade or so a go.
-Jeff
Night riders? Or something similar?
No hi-beams & dash lites get dim peachyracer Defender Technical Discussions 4 December 21st, 2010 04:56 PM
ARB locker? Flagg Misc. Chit-Chat 14 July 30th, 2007 09:07 AM
