MM 4x4 Spring Shock Pairing - Defender Source
Old January 25th, 2011, 12:42 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
So I snagged the MM Springs from Gardner and am now looking for suggestions for which shocks to go with. I currently have the OME HD setup and after 7 years are so it is pretty beat up and starting to sag. Anybody run these have suggestions on a complimentary shock.
I am mostly dirt and mud, so articulation isn't a huge deal. I would also like to keep it fairly steady on the road.
Any suggestions are appreciated.
Bill
Old January 25th, 2011, 06:07 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I have M&M springs and Terrafima shocks. I think it's the perfect setup for my truck. Everything is firm enough for on road (I have a 5" lift and no sway bars), and nice and soft off road.
Semper Fi!
Old January 28th, 2011, 03:37 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Hey Jon did you use the standard pro sport shocks or the ones with the extra 2 inches of travel? Or do you have the model numbers?
B
4x4
Will these work? Shock spring question. tomaco1 Defender Technical Discussions 0 May 5th, 2009 09:34 PM
Rubberized Spring Isolators/ Shock Tower Securing Ring? oldscratchggf Defender Technical Discussions 10 October 2nd, 2006 05:44 PM
Labor Time on Spring and Shock swap 1of40 Defender Technical Discussions 3 June 21st, 2005 10:01 AM
Flatland 4x4 Fest (1998) - Kansas USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 08:35 AM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
