Missing wiring connector 94 D90 - Defender Source
Old June 5th, 2014, 01:43 PM
wesley0620
Wesley Everett
1994 Defender 90
After chasing a 94 D90 flooding issue, a link led me to check the temp sensor near the thermostat that sends input to the ECU. Found that but no wiring is attached to that sensor and no unconnected wires in the area. This vehicle has been running fine for over 4 years without that connection. Still concerned about no codes showing and no check engine light. Injectors are definitely putting too much fuel at start but after start the engine will idle great and drive mostly normal except a slight misfire trying to accelerate in 4th and 5th gear.
Old November 18th, 2014, 08:42 AM
The ecu puts a default value to allow the engine to run. It doesn't run perfectly but will run. It's called limo mode.
Old November 18th, 2014, 08:51 AM
or limp ?
Old November 18th, 2014, 09:32 AM
Grover's Avatar
Grover
I believe the un-connect temp sensor you speak of goes to the a/c fan. Do you have a/c?
Old November 18th, 2014, 03:57 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I second that statement.
Legend in My Own Mind.
Old November 19th, 2014, 10:35 AM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Talking
or limp ?
I like limo mode...
Old November 19th, 2014, 01:29 PM
The temp sensor for the ECU is near the injector for the number one cylinder on the front left of the engine.
90, d90, wiring
1997 d90 wagon missing piece d90boy Wanted 0 November 28th, 2011 04:12 PM
'95 D90 3.9L missing for 10' after start... HMB_Defender Defender Technical Discussions 2 August 7th, 2011 04:10 PM
3-pin male connector for the NAS/post 1995 Defender brake light Pat Wanted 5 May 29th, 2006 10:23 PM
Missing Lever for Bottle Jack on 97 D90 ClanHavoc Wanted 0 May 27th, 2006 09:22 PM
Trailer Light Connector loykd Defender Technical Discussions 3 November 17th, 2003 04:31 PM
