Missing screw from distributor, help - Defender Source
Old February 16th, 2011, 03:34 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Anyone know what size screw that goes in this piece off the distributor assembly?
Or where I can find one to fit it?
Old February 16th, 2011, 06:23 PM
I'll look later tonight as I have a distributor handy I can pull a screw from, but you should have another screw on the other side of the diaphram as well iirc (although it might be harder to get to).
------ Follow up post added February 16th, 2011 07:29 PM ------
It appears to be a m4 0.6 screw, 8mm long (not counting the head). The original screw has a T-15 torx head, but anything else would do.
hth
charles
Originally Posted by pendy
I'm here for the D's
Old February 16th, 2011, 07:39 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Thanks for getting back to me on this. I'll pick one up asap! Got some wheeling up in WI next weekend so I appreciate the quick help!
I owe you a beer!
Old February 16th, 2011, 08:17 PM
JimKo
Jim Kochenderfer
1994 D90
screw
If that's the screw that holds the vacuum advance to the side of the distributor, I lost both of mine in Moab a couple years ago and then my advance unit fell off.....needless to say, performance suffered. After unsuccessfully searching through every screw bin at the True Value hardware, I wired the advance unit back on with baling wire and drive 800 miles home. Once at home I determined the screw to be a rather odd size, M3.5 x 8 and I had to mail-order 100 of them. This is on my '94 D90 ST. If that's the screw you need and you want a couple, PM me your mailing address and I'd be happy to drop some in the mail no charge. Better act fast, I only have 96 left.
Old February 16th, 2011, 09:59 PM
That's the one. If M3.5x8 worked for you then believe that before my measurements!
distributor
snaps missing in roll cage jaherring Defender Technical Discussions 4 March 17th, 2008 11:23 AM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Fastback install - what is missing? paulb Defender Technical Discussions 10 March 17th, 2005 12:28 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
