Missing drain plugs - Defender Source
Old May 30th, 2012, 01:36 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Missing drain plugs
As I was addressing my steering headache. I noticed, I am missing two drain plugs!!!????
Anyone know what purpose?
Name:	power steering gear box 014.jpg
ID:	52366   Click image for larger version
Name:	power steering gear box 015.jpg
Old May 30th, 2012, 01:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You are not missing them per se, they should be open unless you plan on fording water.
Use NAPA #704-1361
A nice little drain plug with a plastic gasket. Works perfectly as a wading plug.
M14x1.5 if you want a bolt (but the NAPA plug is better)
Semper Fi!
Old May 30th, 2012, 02:07 PM
Rosproline157
Matt Oaks
1992 Defender 90
Thanks!
drain, drain plug
transmission drain and fill rover4x4 Defender Technical Discussions 24 November 16th, 2011 02:31 PM
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
Fastback install - what is missing? paulb Defender Technical Discussions 10 March 17th, 2005 12:28 PM
a/c drain Campbell Defender Technical Discussions 3 May 26th, 2004 12:00 PM
