Missing cover......now oil leak. - Defender Source
Old June 23rd, 2014, 01:08 PM
azspeed
Greg
85D90
Trying to pinpoint some of the oil leaks on my 85 2.5 NA, after pressure washing/degreasing the motor I climbed underneath to find what appears to be a missing panel/cover/???? on the front side of the oil pan beneath the crank pulley where there is a healthy oil leak coming out. Does anyone else with a 2.5 NA know what is supposed to go there? I've attached a picture, from my diagnosis there are 4 holes where a cover could be secured, however if it just means oil will then be pooling inside than that may not be the solution either. Thanks in advance.
ID:	97430   Click image for larger version
Old June 23rd, 2014, 01:19 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I think that goes into your timing belt area. If so, I'd want it covered better than that. Maybe make a cover with a small drain hole init. However, if you have a ton of oil leaking into that space you may have bigger problems.
Old June 23rd, 2014, 07:51 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
This is a shot of my 2.5NA diesel. You do seem to be missing the cover/wading plug.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old June 23rd, 2014, 08:24 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You gots your self a leaking crank/cam shaft seal there my old son, just finished doing one like that.
If it is a small leak don't plug it up till you get it fixed, timing belts don't like sitting in oil for too long, you can combine this fix with a belt change as it looks like you just got the 90, you can do all this with the engine in place.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 23rd, 2014, 08:35 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Yuppers. Time to pull the front cover and do that timing belt/oil seal thing. Pretty straight fwd. If you dont have a locking pin for the flywheel....a 6 mm allen works very well.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 23rd, 2014, 09:51 PM
Sell him the missing cover Rick, you have a half dozen spares.
Old June 23rd, 2014, 10:19 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Instead of trying to fix that turd sitting in your engine bay, replace it with a 200tdi or an OM617. Hell, even a half dozen hamsters from your local pet store will pull better than that dirty, smelly, under powered, leaky 2.5 ltr shit box of a motor.
Old June 24th, 2014, 06:52 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Leaky? Really? Mine dont leak....or smell any more. Now...the slow part....well....dam.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old June 24th, 2014, 09:05 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Give it time
Old June 24th, 2014, 09:35 PM
azspeed
Greg
85D90
Thanks for the advice everyone. I did just purchase it, and actually had the timing belt changed, but not the seal, hindsight..... I guess it'll be coming off again. I would love to drop a 200TDI in it, but at this point, it's not worth the investment to me. The motor still runs and drives great, so I'm just gonna fix the oil leaks and enjoy it as is.
Old June 26th, 2014, 07:13 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Well...if you where closer we could do this together. Seems mine yacked the new cam seal last pm. I am getting kinda good at this front cover/timing thing.
@ Raub: I will go to a LR3/4 before a 200tdi!
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
cover
WTB: Missing lower dash cover... dlee888 Wanted 0 March 30th, 2011 07:13 PM
WTB: Missing lower dash cover... dlee888 For Sale - Parts 3 March 23rd, 2011 04:37 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
Changed Thermostat now coolant leak 97-D90-736 Defender Technical Discussions 3 January 3rd, 2010 11:09 PM
