Missing bolt or ? - Defender Source
Old May 25th, 2011, 11:22 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Missing bolt or ?
I need some help with this one. The cantrel and C pillar are pulling apart. Looks like there may be a bolt missing. Previous owner removed seat belts when he put in jump seats.
Thanks in advance
Old May 25th, 2011, 11:24 PM
Yup. Bolt is missing. It is a seat belt bolt, but at least you have the spacer.
Old May 25th, 2011, 11:27 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Thanks. Where do I get the bolt, or what size is it? Do i need to push that spacer back in? What is easiest way to get cantel and c pillar back together?
Old May 26th, 2011, 12:22 AM
I would order from RN as IIRC (and memory is failing on this) it is a fine thread metric. The spacer is in all the way and I think there is a metal collar as well. I would take a rachet strap and run it to the b-pillar and pull them together, actually no I would not, but that is the easiest way. I would stand in an awkward position over the spare and push the c-pillar forward and try to fidget to get the bolt in and probably hurt myself.
Old May 26th, 2011, 12:27 AM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Check the others.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 26th, 2011, 12:31 AM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Anyone have 2 of these for sale? Insert is sticking out about 1/2". Is that normal? Ron IIRC, is that a part #? Sorry, I am clueless
Old May 26th, 2011, 12:40 AM
bjf's Avatar
bjf
barry f
94 ST #395
I have never checked this. So the rear part of the cantis are held in by the seat belt bolts? These bolts are not the same as the other cage bolts? Not even in pitch?
Old May 26th, 2011, 12:55 AM
If I Recall Correctly = IIRC
Old May 26th, 2011, 10:51 AM
Mark, the purpose of that spacer is to allow the seat belt hanger to sit on the step in the spacer and swing freely while the bolt is tight up against the spacer. As shown it's fine - just put a bolt in and push the rear C-pillar forward until that gap is gone and the bolt should thread right in.
If you have the bolt on the other side, simply remove it and take it to a hardware store and match up the size and thread.
Originally Posted by pendy
I'm here for the D's
Please help me identify this missing bolt drv2fst Defender Technical Discussions 10 July 26th, 2010 10:42 PM
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Bolt attachment for a Southdown steering guard paulb Defender Technical Discussions 3 January 20th, 2005 08:42 PM
