Miss Firing on Plug one - Need Advice - Defender Source
Old May 18th, 2012, 02:24 PM
usadventureracing's Avatar
usadventureracing
Brett
110
I have a 3.5 and drove it for the first to the gas station after my "rebuild". I have loss of power and when I hook my timing light to the 1 plug it seems to be miss firing. The light will blink then stop and start. I removed all plugs and cleaned them. What should I be checking? Thanks in advance.
Brett
1983 ROW D110
1970 Series III (Parting out)
Old May 18th, 2012, 02:40 PM
Naplm00
Matthew
I would check the wires form the cap to the plug, switch #1 with another known good wire and see if that one then misfires. You may have a bad wire.
Also check under the cap for a bad contact
may want to also change that plug for a good one
Old May 18th, 2012, 03:03 PM
usadventureracing
Brett
110
Switched wires no luck, looks like I'd also doing the same thing when I hook the timing light to it.
1983 ROW D110
Old May 18th, 2012, 03:11 PM
swap and arm for a known good one
Old May 18th, 2012, 03:17 PM
usadventureracing
Brett
110
8 was also miss firing. I will a new rotor a and see what happens
1983 ROW D110
Old May 18th, 2012, 05:59 PM
usadventureracing
Brett
110
I ordered a new rotor arm but I replaced the cap and rotor late last year and never touched those parts during the rebuild. I looked at them and there appears be to no issue with them no Arking (sp).
Any thoughts on why both the 1 and 8 are having issues. I am going to purchase 2 new plugs on saturday and I found extra wires as I want to try that again.
1983 ROW D110
Old May 19th, 2012, 04:49 PM
usadventureracing
Brett
110
Fixed it last night with new plug and wire. Ordered a new set of wires to replace all of them.
1983 ROW D110
Old May 20th, 2012, 08:59 AM
Naplm00
Matthew
Nice, good thing iT was something cheap
Old May 20th, 2012, 03:18 PM
usadventureracing
Brett
110
Yes I know I need a break from spending rover money. Still need to complete my interior but I can do that overtime now and still be able to use the 110
1983 ROW D110
Old May 21st, 2012, 06:03 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Just saw this thread. I was having a similar problem a few months ago, and the check engine light was coming on. Mine turned out to be plugs. I was using Bosch Platinum plus 4 plugs, and have since seen others say they've had problems with those too. Replaced them with some run o' the mill Champions and it runs great.
Pete
OBD Plug no power??? Cyborg Defender Technical Discussions 4 December 29th, 2005 11:29 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
