misfires at low rpms sometimes - Defender Source
Old November 30th, 2006, 04:11 PM
jdb3760
Jake Buinewicz
95 Defender 90 softtop
Question misfires at low rpms sometimes
I am utterly confused about this one. I took the D90 up to paragon and was going through some water and after the water crossing maybe 30 seconds later it stalls. I check the distributor, spark plugs, intake and everything is dry. Then I try to start it and it cycles but it doesn't fire. After about 2hrs of debating whether to get a tow truck and trying to start it every now and then it finally starts to run. It only ran on a couple of cylinders for a while then out of know where it runs fine. This offroad trip was 2 weeks ago and it ran fine since then and now for a weird 5 min period today it started to miss at low rpms. Then the problem went away again and now it runs fine. The check engine light came on when I was up at paragon but I haven't had time to take it to the mechanic. Does anyone have any idea what I got wet or did?
Jake
Old December 3rd, 2006, 09:50 AM
tron's Avatar
tron
Thomas F
Recently Roverless
What code are you getting with the check engine light?
fire, misfire
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
'97 Defender LE - Low Miles Weaver For Sale - Vehicles 1 May 24th, 2005 08:22 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
