Misfire mystery - Defender Source
Old October 5th, 2014, 09:04 AM
Misfire mystery
I have a mild misfire ... Bizarrely enough this has coincided with me getting the best gas mileage I've ever got!
Coil is genuine Bosch and new.
Leads, cap coil are all good.
I haven't pulled the plugs yet..
Ideas?
Old October 5th, 2014, 10:23 AM
What conditions does it misfire?
Old October 5th, 2014, 10:25 AM
Driving ... You feel it more under load.
Old October 5th, 2014, 11:41 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
aftermarket wires ? if not sticky valve syndrome comes in at 30k-60k intervals
No Mall crawler here
Old October 5th, 2014, 11:45 AM
There is a bad batch of Bosch coils going around. Me and a local buddy both got one.
If yours is recent it could be one of the bad ones.
Old October 5th, 2014, 04:53 PM
Got worse today after driving for a while. Definitely seems related to temp.
Old October 5th, 2014, 08:10 PM
Will you be around this week? We can take a look at it one night after work.
Old October 5th, 2014, 10:37 PM
Yeah I'm around all week. Another a set of eyes on it would be great! Let me know what works as traveling to Canada later in the week.
Old October 7th, 2014, 07:32 PM
And it's fixed. Thanks Jimmy!
Old October 7th, 2014, 07:43 PM
Solution?
Old October 7th, 2014, 08:23 PM
WTH what was it?
Old October 7th, 2014, 08:53 PM
Dry electrical connection.
Old October 7th, 2014, 09:41 PM
what is a dry connection?
Old October 7th, 2014, 09:43 PM
Prolly auto corrected version of "dirty"
Old October 7th, 2014, 09:50 PM
That's typically a good thing! We found some slight corrosion on the connector for the ignition amplifier module. I was watching his scan tool as he was driving and saw some 'glitch' type readings, so he got some contact cleaner a dielectric grease and started pulling connectors. That was the only one with any signs of corrosion, and after cleaning it, the truck ran much smoother.
Old October 7th, 2014, 10:17 PM
nice job!
Old October 7th, 2014, 11:11 PM
Using the term dry as in dry solder joint where the connection is bad.
I cleaned TPS, coolant temp, fuel temp, ignition connections at the MAF sensor connectors with electrical cleaner then dolopped a splodge off dielectric grease to keep them clean.
Was surprising how it ran so much smoother.
Old November 18th, 2014, 08:39 AM
And it's back ... It's definitely worse when warmer. Appears to disappear at higher revs ... From 3-4k.
I did get a few pops in the exhaust accelerating from slow speeds in high gear.
Coolant temp seems ok but maybe I'm running the engine a bit on the cool side at about 80 Centigrade. Or 176F.
O2 sensors have not been replaced and maybe next on the list.
Old November 18th, 2014, 08:58 AM
LR Max
Thomason, Max
1973 Series 3 109
Did you ever pull the plugs?
I worked on a P38 that had a misfire on Cyl 8. Ended up being an improperly gapped plug. Brand new OEM plug too.
Dunno, just thought I'd throw out a cheap and easy thing to check.
Old November 18th, 2014, 09:51 AM
jafir's Avatar
jafir
Jafir Elkurd
If it's worse when warmer, I blame the ignition amplifier. Especially if it's been replaced with something cheap at some point.
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
200tdi mystery misfire bossman429 Defender Technical Discussions 22 March 13th, 2013 09:33 PM
ignition/engine misfire code (sleuth work needed) hlamar Defender Technical Discussions 7 July 19th, 2010 08:06 AM
misfire dosepe Defender Technical Discussions 2 April 18th, 2007 08:50 AM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
