Misfire mystery - Page 2 - Defender Source
Old November 18th, 2014, 12:36 PM
If it makes you feel any better, I have a misfire too now. Mine only happens at a cold start when it is cold outside.
Old November 18th, 2014, 12:49 PM
Originally Posted by LR Max View Post
Did you ever pull the plugs?
I worked on a P38 that had a misfire on Cyl 8. Ended up being an improperly gapped plug. Brand new OEM plug too.
Dunno, just thought I'd throw out a cheap and easy thing to check.
I'll try that ... thanks
Old November 18th, 2014, 12:51 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Popping is a symptom of a lean condition... could be caused by a number of things from MAF to TPS to 02's to dirty fuel injectors.
If it's bad enough, this can internally damage the engine (lean = hot)
Old November 18th, 2014, 12:52 PM
Actually it makes me feel worse .... what I need is an app to measure engine smoothness ... that way I can twiddle with stuff until it smooths out
Old November 18th, 2014, 10:27 PM
doscazadores
Vic Stull
none
Same issue with my '98 D90. Turned out to be slightly corroded contact points in distributor cap. So replaced it, the rotor, and since we were pretty sure a couple plug wires were fubarred as well replaced all plug wires. Problem solved. Might want to check.
Old November 19th, 2014, 07:41 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Interesting. Your 98 has a distributor?
Old November 19th, 2014, 09:23 AM
doscazadores
Vic Stull
none
Don't be a hater! Pretty funny actually. Might have to go look but last time I checked it was a '95.
Hold on a sec . . ..
Yup, it's a '95.
Old November 19th, 2014, 12:04 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Get back to basics air,fuel,spark ! say it in every training class i give don't be blinded by electrical glitches or you will be chasing ghosts for a very long time .
No Mall crawler here
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
200tdi mystery misfire bossman429 Defender Technical Discussions 22 March 13th, 2013 09:33 PM
ignition/engine misfire code (sleuth work needed) hlamar Defender Technical Discussions 7 July 19th, 2010 08:06 AM
misfire dosepe Defender Technical Discussions 2 April 18th, 2007 08:50 AM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
