misfire - Defender Source
Old April 17th, 2007, 09:30 PM
dosepe
douglas sepulveda
1997/D-90
misfire
truck runs great but the check engine light stays on a multiple misfire code keeps coming up
Old April 17th, 2007, 09:55 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I just did a quick search on the site and did find some info for you. Go up to search and in the search field type in P1317 that should lead you to lots of great info that will help you out.
I believe you spoke to me at AB today this site will be a great help to you. The guys here have been great to lots of customers that I have sent over here over the years.
Good luck
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old April 18th, 2007, 08:50 AM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Black 1997 D-90 soft top
Location: Delray Beach, FL/ Bequia, St.Vincent & Grenadines
My check engine light has been coming on regularly for the last year always the missfire 1317 code. I have a OBII scanner and clear it myself. I was told by a few people on this board and by the LR dealership that it is pretty common occurence with 97 D-90s and nothing to worry about as long as it is that code. After clearing it, the light returns about every 5th time I start the truck. PITA but I have learned to live with it...I would undo the bulb, but then if the light did come on for something more serious I wouldn't know
I usually ignore it for a little while and then check it to be sure it is not a different code than the ever present 1317
If I am making a mistake somebody please let me know....
fire, misfire
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
Continous Knock Fault chrisconnie Defender Technical Discussions 5 September 10th, 2007 08:28 PM
Rough Road Sensor?? scubadanster Defender Technical Discussions 25 April 19th, 2007 02:00 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
