mirror mirror on the wall - Defender Source
Old July 21st, 2011, 11:17 AM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
driver side wing mirror always collapses when going above 70. passenger side is fine. any suggestions to stiffen the bearing/hinge?
Old July 21st, 2011, 11:29 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
You don't have an adjustment screw on the bottom of the mirror?
Old July 21st, 2011, 11:32 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You get above 70?
My oil line fix
My 100k stopped odometer fix
Old July 21st, 2011, 11:35 AM
discotdi
Todd Miller
Land Rover
Originally Posted by Hans View Post
You get above 70?
Old July 21st, 2011, 11:38 AM
kevkon's Avatar
kevkon
kevin
You get above 70?
Good point, maybe LR designed the mirrors to fold at 70 just for that little extra aero drag reduction.
Old July 21st, 2011, 11:42 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
There is an allen screw in the base (hole) of the mirror. 4 or 5mm, I think.
Old July 21st, 2011, 11:48 AM
Yep, what Dennis said. Picture 2, here. Tighten them up.
http://www.defendersource.com/forum/...43&postcount=4
Old July 21st, 2011, 02:28 PM
brettm's Avatar
brettm
Brett
well it does have an allen key, but it seem pretty useless. i crank it down and no effect on stiffness... however, i just noticed that the arm that the mirror sits on on the drivers side was a 90 degrees to the body and passenger side was at 45, so i moved them to the same, perhaps that impacts the angle the mirror faces enough to reduce drag?? ..
over 70... with the 4.6 - heck it does 80 before breaking a sweat; feels bizarrely fast for the aerodynamics of a landy.
Old July 21st, 2011, 03:15 PM
If it's just spinning, then it's not catching any threads. Remove the mirror and see if you can get it to catch when not on the mirror arm. My mirror arms are set at two different angles for greater visibility on the road, too.
Old July 21st, 2011, 03:20 PM
kevkon's Avatar
kevkon
kevin
You can remove the mirror glass and see how the tension screw works or why in your case it doesn't seem to be. Or just buy a new mirror head.
Old July 21st, 2011, 04:46 PM
Mine used to do that i just moved the mirror arm in one notch that fixed it.
Old July 21st, 2011, 05:25 PM
You get above 70?
It's funny you say that. My passenger side mirror slowly tips backwards when I drive for extended periods over 70mph too! Too lazy to tighten it (or it's not bad enough to care)
Originally Posted by pendy
I'm here for the D's
Old July 21st, 2011, 07:27 PM
brettm's Avatar
brettm
Brett
you have a series II doing over 70 for extended periods? nice.
Old July 22nd, 2011, 07:53 AM
Nope, in my D90. But I can hit 70 in the series...downhill .
Dropped cylinder wall? jetmech Defender Technical Discussions 6 February 11th, 2010 09:45 AM
Dendy's 110 Disaster Averted-Higher Power!! NashvilleRover Misc. Chit-Chat 9 August 7th, 2009 07:48 AM
Beating my head against the wall a bit. huck1974 Defender Technical Discussions 10 December 19th, 2008 07:27 PM
Roverdrive in Tdi? JackW Defender Technical Discussions 5 March 22nd, 2006 07:55 AM
New tread pattern for BFG MT sheki Misc. Chit-Chat 15 September 16th, 2005 09:16 AM
