Minor rust on safari cage - Defender Source
Old December 23rd, 2008, 02:17 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Hi, I sprayed waxoyl to the undercarriage of my '97 SW (learned after exhaustive forum searches/reading) on all unpainted surfaces, but I have some small rust areas on my cage/related bolted areas.. Can I just sand those off and spray waxoyl directly on the cage, painted or no? No luck w/searches on that subject. Thanks.
-Ren Ching
Old December 23rd, 2008, 02:19 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I'd make sure you still paint it.. sand off the rust, paint over it, then waxoyl it.. waxoyl is only temporary, and if you dont cover the bare metal with paint, it'll rust down the road..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old December 26th, 2008, 12:29 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
I found that duplicolor flat black looks remarkably similar to the original color of the powder coat on the cage, but if you are going that far you may as well rough the powder coat and spray the entire cage bar to make it look uniform. I also found that spray on truck bedliner is very durable and easy enough to apply to the cage.
S-P
Old December 27th, 2008, 09:46 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I wouldn't. I sprayed the rear cross member after a similar episode. It was messy for a long time to say the least. Never liked the texture of it outside of the frame.
Take the cage off, galvanize it and then have it sprayed. Problem solved.
Old December 27th, 2008, 11:54 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Yeah, you just can't beat galvanizing for durability. It even hardens the surface steel in the process.
Old December 28th, 2008, 12:24 PM
Grover's Avatar
Grover
Thumbs up
Repainting the entire roll cage because of minor rust around the bolt hole area seems to be overkill to me.
I used SEM Rust Shield frame piant for similar situations.
Just remove a bolts from one side at a time (so the roll cage stays attached). Lift up on roll cage, about 1/4" or so, just enough to spray Waxoyl 120-4 between the roll bar plate and the mating plate on the fender.
On the roll bar plate, sand around the holes, apply 2-3 coats of paint. Lightly apply Waxoyl 120-4 around each hole, this will lubricate the surface to avoid scratching the paint, then install a nylon washer and the remainder of the hardware...
Good luck!
cage
Safari Cage Restoration Advice mattarm Defender Technical Discussions 17 September 7th, 2007 11:29 AM
safari or roll cage? jonny wrench Defender Technical Discussions 1 January 6th, 2006 08:39 PM
Rear Safari Cage boshea Wanted 2 December 28th, 2004 05:20 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
Rear Safari Cage boshea For Sale - Parts 12 July 1st, 2004 09:07 PM
