Minimum Rotor Thinkness (Genuine LR) - Defender Source
Old April 25th, 2010, 11:24 AM
Grover's Avatar
Grover
Question Minimum Rotor Thinkness (Genuine LR)
Question pertaining to a my 95' NAS D90
What is the minimum rotor thickness for Genuine LR rotors, both front and rear. The shop manual states minimum pad thickness to be .125" (3mm), but nothing about minimum rotor thickness.
Cheers...
Old April 25th, 2010, 04:29 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
According to Rave, "reclaiming" (machining) the discs the minimum thickness allowed to take them down to is:
Front discs: 12mm (0.47") solid discs
22mm (0.90") Vented
Rears 12mm,
Although the discs should have the minimum thickness stamped on them.... looking through the workshop manual (strange that this figure isn't give in Rave), it states:
Wear limit..
90: 0.38mm (0.015")
110/130: 1mm (0.04")
Per side of disc, so presumably you're supposed to scribe a perfect line around the circumference when the disc is new, then measure outwards from each side! or just double up the allowed wear and take that away from the allowed reclaimed thickness....which will give the absolute minimum allowed (reclaimed thickness minu wear)
therefore.... 90 is allowed 0.76mm wear (0.38 x 2 = 0.76mm off of a reclaimed 12mm solid - 0.76 = 11.24mm minimum, or 22mm - 0.76 = 21.24mm minimum vented
110 is allowed 1mm wear, so off of a reclaimed 12mm disc, that takes it down to 10mm minimum
Clear as mud eh???
genuine
1/NEW Genuine LR Alternator Belt- 90/110 $10.00 NashvilleRover For Sale - Parts 2 October 6th, 2009 11:38 PM
2/NEW Genuine LR Fan/AC Belts- 90/110 $20.00 for both NashvilleRover For Sale - Parts 3 October 6th, 2009 11:37 PM
Genuine LR basket (only)- customized... dmarchand For Sale - Parts 24 September 12th, 2005 10:27 PM
Genuine LR Defender radiator crobinson For Sale - Parts 2 August 11th, 2004 10:24 PM
Genuine LR Steel Wheels, or NATO? ronward Defender Technical Discussions 4 March 3rd, 2004 04:23 PM
