Mileage vs. Value - Defender Source
Old May 11th, 2006, 06:25 PM
Cayoweso
Ed Paez
1997 Defender 90 Soft Top
Mileage vs. Value
I am looking to buya D90 , the guy had it serviced and at the last service his mileage showed 37,000 then 8 months later he had it serviced again to replace the speedometer that stopped working. The new speedo now shows 17k but since there was a gap (as to when the speedo broke and when he had it fixed) I am told it is a TMU (total mileage unknown) how much does this affect the value of the D90? Does the 97 come with a digital recorder of the actual miles or is it guess work?
Old May 11th, 2006, 07:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The odometer on a 97 is an electronic digital piece. I really cant say how much it would affect the value though, other than it would reduce it somewhat. But how much, I have no idea.
-Hans
My oil line fix
My 100k stopped odometer fix
SYoung
Steve
94 D-90 #8
How much do you trust the story about it? Condition is KING, but that's a dark mark on the vehicle forever-
Old May 11th, 2006, 08:20 PM
Troys
Troy Smith
1995 D90 SW
Ed;
A friend of mine had a 97 and the speedo went out. Dealership replaced it and placed two aluminum embossed labels indicating the mileage and date of replacement. In other words it was clearly documented. One of the labels was placed on the drivers door jamb and the other in the service manual. Personally, I did not feel that it affected the value given that it was well documented and on the up and up. If however you suspect something was fishy, I would just be certain to scutinize the vehicle that much more. Overall condition far outweighs the mileage discrepency.
Troy
Old May 11th, 2006, 09:17 PM
SYoung
Steve
94 D-90 #8
When you have the plates installed that show the odometer replacement, that doesn't equal TMU (true mileage unknown) because they document the miles on it at the time of replacement. There are two kinds of 'em- documented ones and undocumented ones.
Old May 11th, 2006, 10:07 PM
artm
Arthur Maravelis
97 SW
It is rather stupid of LR not to keep the mileage reading in the ECU.
What's the date of the service at 37K?
Is he the original owner?
Old May 12th, 2006, 06:54 AM
robisonservice
John Robison
2008 Supercharged Range Rover
The mileage is stored in the engine ECU and you may be able to read it and compare with the owner's statements. But it's not a quick and easy thing - there is interpretation - and you'll need an Autologic or other specialized tool.
As regards the "TMU" question . . . by current Federal law, there is no grey area. Either the odometer reflects the actual mileage, or it does not. The subject truck does not. Therefore the "odometer does not reflect the actual mileage" box must be checked on the odometer statement.
That does not prevent a seller from offering an explanation, but it has no legal weight under current Federal odometer law.
Old May 12th, 2006, 08:52 AM
Cayoweso
Ed Paez
He is the original owner, who used the vehicle recreationally rather than his primary mode of transport. In March 2001 according to LR the mileage was 37000, then in November 2001 (8 months) when he replaced it at LR the mileage at LR's records show 1 mile. No plates, no other info other than the new speedo now shows 17,000m. LR claims it could have broken right after the 37000 service and it took him 8 months to bring it in. How and who knows how to use the autologic.
Old May 12th, 2006, 09:26 AM
artm
Arthur Maravelis
97 SW
So, assuming he purchased it in March 97, he drove it 37K miles in 4 years and then 17K in 4.5 years. Inconsistent but explainable.
Since John has confirmed the actual mileage is in the ECU there's no reason not to have it extracted as part of a professional inspection.
Old May 12th, 2006, 01:44 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Ed, you're looking at a 97 truck with 54-60k on it. That's roughly 5k/year. Not bad for a purely recreational vehicle.
Your original question asked whether this would affect the value of the vehicle. On some vehicles it might have more effect than with a Defender. As someone else stated, condition is far more important than mileage. Having it checked out professionally is, in my opinion far more important. The demand for Defenders in good condition far outweighs some mileage discrepancy.
With regard to you selling it later, the question is how long you plan to hold on to the vehicle. If you plan on driving it for the next five years (and keep records), then there shouldn't be any problem at all when you go to sell.
The one big exception here would be if you're planning a ground up restoration and then plan on selling the truck some place like the Barrett-Jackson auction -- something fairly unlikely for a Land Rover.
Old May 12th, 2006, 05:19 PM
scoloco's Avatar
scoloco
'94 D90 ST
On paper - yes the value will be affected. In reality, probably minimal. As others have stated, condition is MUCH more important and defenders are not a dime a dozen. As time goes on and the truck gets older, this should become less and less of an issue.
What's the actual Mileage? 1of40 Defender Technical Discussions 13 April 12th, 2005 08:29 AM
Gas Mileage mdmccallum Defender Technical Discussions 2 October 6th, 2004 12:14 AM
Mileage Question boshea Misc. Chit-Chat 4 April 6th, 2004 03:22 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
low mileage 97 D90 on ebay Chris Cox Misc. Chit-Chat 2 November 26th, 2003 07:17 AM
