Milage/ Speedometer calibration? - Defender Source
Old January 3rd, 2006, 02:13 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My speedometer needs to be calibrated: it runs fast by about 10 MPH. My question is, does this have any affect on the miles on my odometer? I seem to be racking up the miles faster that usual, and I have no clue how the mechanism works. Does the fact that the speedometer is fast have any bearing on how the odometer clocks the miles?
Old January 3rd, 2006, 11:27 AM
Nate - you're not running stock size tires are you? Dont you have 33's or something?
Old January 3rd, 2006, 03:34 PM
oldscratchggf
nate
95 d90
yea, 33`s with 4.10 gearing. It just seems that what should be an 9 mile trip to work is 12 miles with the defender.
By the way, a while back you offered to help me figure out why my clutch is grinding, but it seems to have stopped. Thank you for the offer though.
Old January 3rd, 2006, 03:59 PM
Changing tire size and gearing will absolutely effect your speedo and odo readings. I'd have to sit and think to get it right as to what mod has what effect. I know there are some methods of compensating for the change with new, electronic speedos, but there is no way to simply recalibrate yours. You have a very simple gear turning a very simple cable which clicks over another mile every time it spins 1,000 times.
My truck reads fast even without radical mods. The mileage is right on though. Maybe someone else can chime in.
speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
