Mid-80's D90 Brake Hardline Question (pics) - Defender Source
Old May 2nd, 2011, 03:30 PM
NC Rover
Nick
1971 Series IIa Hybrid
What style flare is called for on the end of the brake line that goes into the master brake cylinder? Single flare or double flare?
Mine are leaking and not mating up properly so I need to re-flare the brake lines.
I have mid-80's D90 brake setup: Solid Disc fronts and Rear Drums
https://lh4.googleusercontent.com/_K...0/IMAG0661.jpg
1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
Old May 2nd, 2011, 04:13 PM
Naplm00
Matthew
Well it would be either double flare or bubble flare, You dont see single flare that often.
single flare is a single non-folded end in a trumpet shape (very old cars)
double flare is a trumpet shape but with the exterior folded inside (standard domestic)
bubble flare is a bulging nonfolded "bubble" on the end of the line (standard euro)
Double Vs Bubble
http://forums.pelicanparts.com/uploa...1201238131.jpg
Single Flare
http://image.customclassictrucks.com...uble_flare.jpg
Old May 2nd, 2011, 04:49 PM
NC Rover
Nick
Double Vs Bubble
Single Flare
When I pulled the lines out, they were definitly bubble flared. Could I find a tool to do a bubble flare at a place like Autozone or do I need to special order the tool? I know you can kind of rig it to produce a bubble flare by reversing the flaring tool.
Also, are rover lines Metric? Thats my other issue..tough to find any metric flaring tools. looks like Home Depot carries some nice ones, but doesnt' say metric...only SAE.
Old May 2nd, 2011, 06:40 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Use your old fittings and grab some 3/16 line from auto-wherever. It is a bubble flare and you should be able to get a kit from the same place of choice.
Old May 2nd, 2011, 07:31 PM
NC Rover
Nick
So far I've been to Autozone, Advanced Auto, and Home Depot. All carry the same dual flaring tool, but none of the tools can produce a bubble flare. Any suggestions?
Old May 3rd, 2011, 01:22 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Most standard flaring kits do single and bubble. True double flare tools are less common in the US. It's possible that the tool itself is named "double flare", but it likely makes what we're calling a bubble flare.
I looked at the one that Autozone lists as their loaner tool, and found the exact same tool on Amazon, it looks like a standard flaring tool to me.
http://www.amazon.com/Astro-Pneumati...4399960&sr=1-3
Tony
1984 110 "Smokey" (sold)
Old May 3rd, 2011, 09:18 AM
Naplm00
Matthew
I think the harbor freight one I have does all the 3 types
Old May 3rd, 2011, 12:51 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The double is the "bubble" here in the states. Just don't clamp soo hard when making the final flare.
Old May 3rd, 2011, 01:25 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
called a metric bubble flare. Very different from a double flare. Dont think Harbor frieght has one (anymore?)
looks like OTC makes one you can get on Amazon for $45. http://www.amazon.com/OTC-OTC6504-Bu.../dp/B00061SMFS
Old May 3rd, 2011, 01:37 PM
lots of bad information in this thread. I've made enough brake lines to never want to do it again. Here goes:
Double flare. See Napalm's post above, this makes a double walled trumpet end. Metric and 3/16 line are basically the same. The single/double flaring kits are very commonly available in the USA and will make these just fine. They won't make a modern ISO bubble flare but the will make a passable old style bubble flare, sometimes, if you hold your mouth just right, and pray to Obama.
ISO/Bubble flare- there are two kinds of bubble. The modern ISO style is commonly found on defenders and US model RRC and possibly discos. They look like the second link in Napalm's post.
The old style or british bubble flare is often found on older series LR's. It differs in that it is rounded more so than angled and the back is rounded as well as the front. As opposed to the ISO style that has a flat back. You can buy an ISO flaring kit that will make a decent ISO flare, I bought one form Eastwood years ago. I did a coil sprung 88 using RR axles and had to make a bunch of the lines for it. I used the ISO flaring kit and it was a bit of a pain to get them right. But, it did work. If you screw up the flare you can just cut it off and make a new one.
I have not ever seen a kit that specifies that it can make proper old-style bubble flares.
3/16 or 4.5 something mm, same line, doesn't matter which you use.
Having said all that, I no longer have the old ISO kit and the last time I needed to use ISO flares, I used adapters to go from metric/bubble to US double. IOW I made short adapter pipes to go from the port on the M/C to the old factory line. That worked just fine though it was not as pretty as nice factory looking line. But it was an old RR that I just wanted to get brake fluid from point a to point b without leaking. I was converting it from ABS to non ABS and a few of the lines were too short.
If I ever buy another flaring tool I will shell out for the fedhill unit or something like it. Those little hand flaring kits kind of suck to use especially if the line is steel, and on or under the car.
I think it is always better to get a factory or aftermarket pipe that is specific to the application.
Whatever you do, double/triple check your work and make sure the flare nuts have good thread engagement and aren't leaking under pressure.
Old May 4th, 2011, 11:36 AM
NC Rover
Nick
Thanks for all of the information guys. I was able to produce the "bubble flare" with the rented dual flare tool from autozone.
This video helped out a bit with the process...
No more leaks and the brake system works great!
Old May 8th, 2011, 07:31 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I have this ISO/Bubble flare kit
http://www.summitracing.com/parts/OTC-4504/
It works fine, though I wouldn't want to do production line work with it.
I don't recommend making "fake" bubble flares by making a partial double flare. While I've done it before when I was young and naive (and the only bubble flare tool I could find in the US was about $300), I don't consider it safe. Brakes are one thing that should really be done correctly. And the tool is cheap enough.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
90, brake, d90
Mid-80's D90 Brake Hardline Question (pics) NC Rover Defender Technical Discussions 0 May 2nd, 2011 03:30 PM
WTB: d90 brake calipers Brendon Wanted 3 October 13th, 2010 12:18 PM
financing question on d90 Kerr Defender Technical Discussions 20 May 31st, 2007 10:10 AM
Question regarding Manual Transmission on 95 D90 DefenderLvr Defender Technical Discussions 9 April 25th, 2006 02:59 PM
