Mid-80's D90 Brake Hardline Question (pics) - Defender Source
Old May 2nd, 2011, 03:30 PM
NC Rover
Nick
1971 Series IIa Hybrid
What style flare is called for on the end of the brake line that goes into the master brake cylinder? Single flare or double flare?
Mine are leaking and not mating up properly so I need to re-flare the brake lines.
I have mid-80's D90 brake setup: Solid Disc fronts and Rear Drums
1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
90, brake, d90
WTB: d90 brake calipers Brendon Wanted 3 October 13th, 2010 12:18 PM
financing question on d90 Kerr Defender Technical Discussions 20 May 31st, 2007 10:10 AM
Question regarding Manual Transmission on 95 D90 DefenderLvr Defender Technical Discussions 9 April 25th, 2006 02:59 PM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
