Michelin XZL Tires - Defender Source
Old June 12th, 2004, 06:47 PM
gearco
James T. Johnston, Jr.
1986 D110
Michelin XZL Tires
Can anyone tell me the width and diameter of the 8.25 R 16 and 7.50 R 16 Michelin XZL tires? this has probably has been discussed here before but i can't find it. thanks
Old June 12th, 2004, 08:38 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
The 8.25R16's are ~34.0"x9.0". I'm not sure about the 7.50's
DJ
Old June 12th, 2004, 10:07 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
from what I understand, the 8.25's are 32.5x8.25 and the 7.50's are 31x7.50.. any idea where to find a set of 8.25's? I would like a set for my series truck.
Legend in My Own Mind.
Old June 12th, 2004, 10:08 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
31" for the 750's
EwS
Old June 12th, 2004, 10:28 PM
gearco
1986 D110
then the 7.50 is a little smaller than the stock tire. the 265/75/16 is 31.6 tall and 10.4 inches wide. is the 8.25 OK for a stock truck, or would i need a lift kit?
Old June 12th, 2004, 11:14 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Well, if the 8.25 is 32.5 as Randy said then you should be fine. However, if it's 34 as DJ said then no. You should at least have OME springs to fit the 34's.
I know 9.00 R 16 is 36.5" which I'm guessing the 8.25 is 34"
Old June 13th, 2004, 02:07 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Thatched roof garage has 5 7.5'smounted on wolf rims. the 825 would be a real hassle to fit - they are 34 or so inches and you would have to do some serious mods to fit. Para only give 2" of lift. The 750's will fit with little to no mods aside from parabolics. Or you can go to Alcan springs and get real spring made with better handling and 2" lift like the para's. They have really cool eyes on the springs called orbit eyes that prevents spring twist. Check them out.
EwS
Old June 13th, 2004, 05:06 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Guys
The 8.25R16's are definitely 34's as I have got a pair currently mounted. As far as mods go Yousef hit the nail on the head; mods are required. To fit the 8.25's you'll need to upgrade your springs to a 3" lift and install a CV-style drive shaft up front (at the minimum). I'm running OME 764's up front and OME 781's in the rear of my SW with the 8.25's coupled with a front GBR CV-driveshaft.
Just from driving around it's also obvious that the shocks need to be displaced as well. I'd recommend either EE's 2" rear shock mount or Scorpion Racing's rear & front shock mount (both allow a 2" drop for your shocks). You can purchase the Scorpion kit from 4x4 Adventure Gear (http://www.4x4ag.com/).
More importantly, where are you going to find 8.25's? I happen to find mine local to Portland, Oregon, however, as far as I know his last set of 8.25's were sold over a year ago. Basically, you're going to have to comb the US for them shop by shop. I would have never found mine unless a fellow Rover-Nut had told me that her next door neighbor had these tires at his shop. If worse comes to worse you can always solicit other countries for them. The UK and maybe Australia might sell them to the public. Hope this helps.
Feel free to ask any quesitons. And if anyone needs pictures I'd be more than happy to help out.
Regards
DJ
Old June 13th, 2004, 11:02 AM
If I may, I think XZL's are an option from Rover if you buy one abroad. I recall because thier was an option for this when you configured the D-90 on the LR webpage......
Old June 13th, 2004, 04:45 PM
scrover
Steve Cooper
93 RRC LWB
Here are the sizes in mms:
http://www1.ocn.ne.jp/~tire-y/XZL.html
8.25R16 converts to 33.86" x 9.05", 7.50R16 converts to 31.57" x 8.27"
Yes, the 7.50s are a factory "off-road" option in Europe.
SC
Old June 13th, 2004, 05:17 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Now the million dollar question, who got some for sale.
Chris von C
[/size]
Old June 13th, 2004, 05:40 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Check the Candian Tire stores. Some had 8.25's for sale - 6 of them. Just google XZL's for sale and you should be able to find some online. Also some military vehicle sites have postings on where to find them - but they are more toward the surplus 900 to 1200's.
EwS
These guys had some late last year. 200 for 8.25's
Bill at Bill's Tires Pacheco, CA, 925.689.2678
Old June 13th, 2004, 06:14 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Thanks Eric, I may start scouting around for the 9.00's.
Chris von C
[/size]
Old June 13th, 2004, 07:14 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Swweeeettt!
Old June 13th, 2004, 08:52 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Check out www.govliquidation.com they had some Michellin tires by the pallet. Dont know what size. Worth looking into though. Just search under tires on there page.
Old June 13th, 2004, 09:15 PM
gearco
1986 D110
does anyone know what the XZLs are like on the road?
Old June 13th, 2004, 11:57 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
They probably produce less noise then the BFG M/T's. I've owned both and think they're somewhat comparable as far as noise level is concerned.
DJ
Old June 14th, 2004, 12:06 PM
gearco
1986 D110
how do they handle on the road?
Old June 14th, 2004, 01:37 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Well, they certainly grab. I never experienced this with my BFG's, but if there's a rut in the pavement those XZL's will pull you right into it. However, this is more likely due to the combination of the aggressive traction & narrow width of the tire. The same is probably true for any tire with these dimensions. Anyway, thatís really the only shortcoming of the XZL's, well, that and they weigh 70-lbs per tire. I wouldnít recommend using the stock Defender tire carrier for an 8.25 XZL.
Off road I'm quite pleased with them. I've run them through loose gravel, shallow sand, snow, ice, over deadfall, & rocks. I used them on just about everything except a nice patch of thick mud. Go figure. Anyway, they certainly get the job done. Although ice and snow are not their strong points in my opinion. It seems as if this type of tire is more suited towards a high desert terrain. Perfect for pushing through scrub brush, sand, & gravel basins.
All around I think itís a good tire. A bit too expensive, but the rubber doesnít appear to be too soft and should last. All things being equal my BFGís wore quicker in the first 10K miles of their life whereas the XZLís donít appear to have worn that much at all.
As for locating them you might want to give these guys a try up in Canada (http://www.tirecraft.com/commercial/MichXZL.asp).
DJ
Old June 15th, 2004, 02:51 PM
d110pickup
Mike Pado
'97 D90 ST #1153
I've got a set on my x-mod 110 and like them. Off road they grip well and seem to shed mud pretty well. On road I've been comfortable at 70 mph all day (drove to MAR and back in Virginia last year). Mine are pretty worn now and I'd like to find another set.
Where are you in Atlanta? I'm in Canton. Are you in SOLAROS?
tire, tires
Michelin XZL 7.5 x 16 Tires for sale SafariHP The Vendors Loft 45 February 9th, 2012 04:34 PM
4 tires Michelin 7.50 R16 XZL 99% New wildthing For Sale - Parts 6 September 16th, 2008 09:57 PM
New Tires 6.50R16 XL XZL Michelin wildthing For Sale - Parts 4 July 24th, 2008 11:14 PM
Michelin X 7.50 R 16 Tire(s) - (Original '93 NAS 110 tires?) roverguy78 Wanted 2 May 31st, 2006 12:55 PM
5 Michelin 7.50R16 XS tires - half worn JackW For Sale - Parts 9 February 23rd, 2006 04:38 PM
