Mercedes Turbo Diesel engine? - Defender Source
Old September 21st, 2009, 03:24 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
I was wondering if the 5 cylinder engine out of the Mercedes 300d Turbo Diesel would make a good power plant for a 110?
IPSC_GUY
SIERRA II ALPHA
Old September 21st, 2009, 07:38 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Scott, someone wants to talk to you, Scoooootttttttt...
- Charles Eames
Old September 21st, 2009, 07:43 AM
what's wrong with the engine that is in there?
IPSC_GUY
SIERRA II ALPHA
Old September 21st, 2009, 02:02 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
http://www.expeditionportal.com/foru...ead.php?t=8169
Very interesting 109/Merc 300TD build along with very good writeup/documentation. The work looks amazingly clean and well thought out.
Old September 21st, 2009, 02:40 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I have a 5 cylinder non turbo in my series III 109. I used the non turbo because I had a 300TD that I drove for decades and I kept the engine after the body rusted out.
The conversion is not as easy as it looks. There are about 50 modifications that must be made for it to fuction properly. First and foremost problem you will have is the shape of the sump. In the non turbo it is not as big an issue. I had the mushroom sides of the sump cut off and an aluminum version of an american v8 style sump fabricated out of the old sump to clear the front diff.
The turbo version has a direct oil line to the sump that will require more fussing in order to solve this issue with obvious ramifications to the life of the turbo if the line is not set up properly.
I am not trying to be negative just realistic. I would love to see a mercedes turbo conversion, I just don't want to be the first guy to do it. I think I was the second guy to do the non turbo conversion.
PM me with your questions.
Old September 21st, 2009, 04:33 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Scott questions will be arriving shortly.
Ohhhh no there is nothing wrong with my 110's engine. I am however plotting the next project before this one is even done.
You see I have inherited a 79 Mercedes 300 SD that no one wants (yeah I know that is funny) with a good engine and I was thinking... find an old 110 and do the swap. That is all. A way to keep a good motor out of a junk yard.
IPSC_GUY
SIERRA II ALPHA
diesel, engine
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
Coil sprung series vehicle w/ diesel engine geneseemtn Misc. Chit-Chat 19 February 26th, 2006 09:52 PM
Defender 90 diesel engine and Electronics? x0054 Defender Technical Discussions 1 July 30th, 2005 10:43 PM
