Medic! Tank just dumped gas - Defender Source
Old June 3rd, 2011, 11:20 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
so i just filled my landy to the point where the pump clicked off, i didn't overfill. i went inside the gas station, came out and saw fuel pouring on the ground. it was a lot - probably a few pints poured out. eventually it stopped pouring. looking under the car it was pouring over the center of the tank on the front-facing side.
any ideas? filler hose? gasket on fuel pump? for the last few weeks there has been a slight gas smell in the garage when i fill it up full, but never seen anything dripping before.
Old June 3rd, 2011, 11:58 PM
brettm's Avatar
brettm
Brett
if it helps, heres a pic of where it ran out. dark spots below the flashlight beam.
Old June 4th, 2011, 08:36 AM
dchapman
Daniel Chapman
1999 D1
Probably either the vent hose or fuel pump gasket. I would guess the vent hose either came off or cracked/split.
Old June 4th, 2011, 12:14 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Yah I'm thinking filler hose, thats the softest part thats exposed under the wheel well tub.
Robert Deniro
Old June 4th, 2011, 05:03 PM
brettm's Avatar
brettm
Brett
leading theory is gasket on fuel pump or breather hose disconnected above the tank like daniel suggested. the filler hose, while ageing with a small crack, didn't appear to be leaking any liquid. the amount that dumped in pretty consistent with the volume that the filler hose would hold. it was a little nerve wrecking firing up the engine, but we siphoned enough out the tank to the point where it wasn't leaking anymore when jostling around.
despite my constant reminder of the in-flames-by-the-roadside-d90 pictures posted on some other thread here - i got her home safe. i will be buying a bigger fire extinguisher
Old June 5th, 2011, 11:34 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'd be fixing the leak personally
Mike Hammond
Old June 5th, 2011, 03:05 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
definitely check that rubber hose that connects... mine came off as well one time because there was no pipe fastener around the end of the hose and it just became disattached. but fuel never spilled of mine so may end up being something else..
I wonder if I can drive over that..?
Old June 5th, 2011, 08:29 PM
brettm's Avatar
brettm
Brett
nah. why waste money on a gasket? i was just going to carry a bucket with me and put it under the tank every time i fill up with fuel to catch the run-off.
Old June 6th, 2011, 01:43 PM
mikeslandrover
Mike Hammond
Mike Hammond
Old July 7th, 2011, 10:40 PM
brettm's Avatar
brettm
Brett
to close the thread. all fixed, not 100% sure the exact culprit, but fuel-pump gasket, breather-seal were pretty damp and deteriorated and the filler hose was old and cracked.
replaced all the seals and put in new fuel pump while the tank was dropped.
gas
Condensation in gas tank Antonios Defender Technical Discussions 25 March 25th, 2006 09:38 PM
WTB: NAS 90 rear gas tank headdamage Wanted 11 March 8th, 2005 02:46 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
