Mechanical temp gauge install Q's - Defender Source
Old October 3rd, 2006, 11:02 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
I want to swap to a mechanical temp gauge soon to keep close tabs on my elderly engine. Is it just a matter of :
1 swapping gauges in dash,
2 routing capillary tube, and
3 swapping sender fitting in engine compartment?
Anyone with a part# for the sender fitting?
Any tips for routing the tubing? Did you need to drill a new hole in the firewall?
thanks
~Steve
Old October 3rd, 2006, 12:53 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I ran capillary tube through existing hole in firewall, then into the radiator (new fitting) just under the top tube. Totally manual thermometer, no voltage needed for it to work. For me it's an extra gauge, not in the dash, but under, in front of fuse box.
Old October 3rd, 2006, 03:08 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Thanks Doug, sounds like a good idea..
Do you think that might be a better place for the sender over factory position?? I guess to see what is actually passing through your thermostat its a good place.
~Steve
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
