mechanical anti-theft system - Defender Source
Old July 25th, 2006, 08:06 PM
Pat's Avatar
Pat
Patrick M.
D90 '96 300Tdi 5 speed
This Italian company sells an interesting mechanical anti-theft system.
http://www.mecklock.com/english/e_default.htm
Does anybody know if we can get something similar in the States?
Pat
Old July 25th, 2006, 09:45 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
looks good. I don't see why we (US Customers) can't order it.
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old July 25th, 2006, 10:21 PM
its neat but it costs a lot. I think its several hundred pounds.
Old July 26th, 2006, 04:44 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
I called months ago as I was obviously interested but they didn't tell me how much,and invited to go and visit them...
It's close to me but I haven't had the time yet
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old July 26th, 2006, 07:21 AM
I was thinking about this. why not just pull the plug on the coil or the fuel pump relay? simple and effective
Old July 26th, 2006, 09:23 AM
Pat's Avatar
Pat
Patrick M.
My point asking about some US supplier was the crazy price the Italians/Brits ask for the thing (if you're lucky getting a quote).
It seems to me it's pretty simple and easy to fabricate. Does anybody know who might be able to fabricate this?
because a thief is able to go around that in 5 secs...
In the other hand the hydraulic system can be "bypassed" but the thief must be a mechanic + tools + a lot of time... I think this system is not perfect but definitely stops the occasional thief..
Pat
Old July 26th, 2006, 09:49 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
One of our customers just sent us one of these to put in his 110. It came from MUD-UK
phone # 01422 847704 or 01422 843397 are the phone #s on the flyers inside the box.
Its a nice piece, but just FYI it comes with all copper plumbing. We swtiched it over to SS lines instead, but the unit works well.
Email:
Old July 26th, 2006, 10:30 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Speaking of Anti theft, anyone done something for the Tdi? Like a hidden button for the ignition, etc? I've had it on my list of things to do. Curious what others have done.
Old July 26th, 2006, 12:03 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
I am planning to make one for my 90, basically the core item is a key controlled hydraulic shut off valve. Jus haven't waded through the RS components catalogue yet to see what is available off the shelf. The rest is just a bit of plumbing on the clutch line
Old July 26th, 2006, 12:04 PM
Pat's Avatar
Pat
Patrick M.
http://www.mudstuff.co.uk/Meck_Lock.html
Meck Lock System® Valve Only: £370.00
I have a hidden button that prevents the injection pump solenoid working normally if not pressed before to start the engine.
It seems to me it isn't just a shut off, it is a one-way valve with some small "relief" to avoid keeping the system with high pressure for long periods if the brake was pressed accidentally when the system is armed.
Please let us know if you can make it, I'm interested.
Pat
Old July 26th, 2006, 12:54 PM
I wonder how many could easily diagnose a fuel pump relay? serious its easy cheap and very doable
Old July 26th, 2006, 02:36 PM
ECR's Avatar
ECR
It would stop a thief on a V8 90 as they need to be quick (unless they bring a flatbed!).
Anything you do out of the ordinary stereo shop alarm install will defeat a common thief as I don't think they have time to go looking for hidden switches and missing relays. I rather have a hidden switch or a missing relay than an alarm any day.
For fun when we remove alarm systems here at the shop we alwasy activate them and then see if we can remove the entire system without it going off. So far I've only had one go off on me and I've cut out dozens.
Email:
Old July 26th, 2006, 07:16 PM
I have a 3 position fuel switching valve: front tank, rear tank, and off. The truck runs for about 30 seconds before it starts starving for fuel.
Old July 27th, 2006, 10:26 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
Pat
I was planning on locking the clutch rather than the brakes. For those thinking about locking the brakes have a look around at companies supplying brake lines and equipment for drag racers. They use a Line lock whch effectively locks the front brakes on
Old July 27th, 2006, 10:44 AM
ECR's Avatar
ECR
Be careful as here in the US most states will not allow a line lock style device in a street car. Micro locks and such are a no-no. Most inspection places have no clue about this stuff and will never catch it if you install it, but technically they aren't legal on the brake system.
Email:
Old July 27th, 2006, 12:19 PM
Pat's Avatar
Pat
Patrick M.
The system can be installed on the brake, clutch or both, but I agree with ECR there might be legal issues involved if you touch the brake line, the same thing happens in UK.
Pat
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
