Mean Green or other HO Alternator - Defender Source
Old June 18th, 2012, 05:41 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
Looking for a alternator that outputs around 180 amps and would bolt up to a 200tdi stock location?
anyone know of a direct fit?
Old June 19th, 2012, 09:43 AM
Naplm00
Matthew
Unless you are running serpentine belt that going to be hard to do. Vbelts wont be able to even turn a alt with that high of an output without slipping
Also you have a disco or defender 200tdi?
The disco version stock location is much easier to find a HO replacement.
Defender motor is much more challenging. Best i found was a new 75 AMP and i had to reuse my old pulley
EDIT
Found the post http://www.defendersource.com/forum/...tdi+alternator check the last few pages
Old June 19th, 2012, 10:14 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
There are plenty of V belt high output alternators. Check out http://www.premierpowerwelder.com/specs/ppwspecs.html
I plan on installing one of theirs when I install an on board welder.
Semper Fi!
Old June 19th, 2012, 10:34 AM
No way it will work on a Defender 200TDI. The V-belt wrap angle is tiny and there is very little room available. At 100 Amp they have trouble with the belts.
Old June 19th, 2012, 10:36 AM
Wolf Fabrication
Sterling Archer
'08 D3
Even on the Disco 200tdi it sucks. My belt is so short and it leaves very little room for tightening. I'm trying to find a better solution for a high output alt as well.
Semper Fi!
Old June 19th, 2012, 10:49 AM
Gibraltarjim
James
lightweight 200tdi conversion
Fit a second alt on the top where Aircon goes, eBay have plenty of units ffor under 60 pounds
Old June 19th, 2012, 03:48 PM
Naplm00
Matthew
yep there is some guy who sells a kit on ebay.co.uk
but you have a pulley and a open timing case with it
Old June 19th, 2012, 03:55 PM
A 180 A alternator is gonna be honking huge, at least a true 180 A alternator will. About twice the size of your standard issue Delco or Marelli. For what reason do you need such a monster?
Old June 19th, 2012, 04:05 PM
SURVEYOR
Dennis Saltys
97 D-90 LE #290
Not in the stock location. Advertised on Land Rover Exchange
Top of Form
Advertisement to SELL; Product: PARTS; Price: 349.99; (Currency: US Dollars);
Defender 200 AMP Alternator Conversion Brackets for 200 TDI
Bottom of Form
200 amp alternator kit for 200 TDI Defender. This kit lets you mount the most reliable high output alternator that we know of on the left side of the engine away from the exhaust. Will work with both the Defender or Discovery 200 TDI Turbo locations and repositions the alternator on the opposite side of the engine where it remains undamaged by exhaust heat. Another positive feature is that when the alternator is repositioned on the left side of the engine it opens a pathway for the intercooler plumbing that allows an easy fit for the Discovery 200 TDI in a Defender. Not for use with vehicles with AC. This advertisement is for the mounting plate, adjustment arm, twin groove pulley, mounting hardware, fan belt, and wiring connectors. The alternator is purchased separately, but we supply the vendor purchase information. We used this setup while camping to run a twin battery isolator for a deep cycle battery that is separate from the vehicle battery. The deep cycle battery powers and Engel refrigerator/freezer, 12V lights, and a power inverter. Please send us an email for purchase information. This is a professional kit that is proven to work effectively.
Top of Form
Robert Davis.
Chesapeake, Virginia, United States of America - 2 May 2012
Bottom of Form
Old June 19th, 2012, 04:19 PM
$350 with no alternator? Holy crap!!
Old June 19th, 2012, 04:21 PM
Naplm00
Matthew
might be easier to just run 2 stock ones
Old June 19th, 2012, 05:03 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
I have a defender 200 tdi
Im looking to have 2 batteries so when we camp we can run a fridge - charge up phones etc while camped - I have set up the 2 batteries with an isolator but I dont think my alternator has enough juice to charge them
my mechanic put on the 12088n one mentioned in the other post but he does not feel it is going to be enough to charge both batteries
Old June 19th, 2012, 05:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
I thought the same thing!
------ Follow up post added June 19th, 2012 05:07 PM ------
I run two Optimas with tons of electric crap (winch, fridge, lights, chargers, etc) on the stock alternator. You're fine.
I'm looking for a high output to run a Premier Power Welder.
Semper Fi!
Old June 19th, 2012, 05:20 PM
The batteries have nothing to due with how big an alternator you need. It is the load. All you mention is a fridge and charging phones.... That is nothing.
Old June 20th, 2012, 02:43 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
I'm only getting around 12-12.6 on either battery ? Which won't charge them correct?
BUY SOME SHIRTS ---> OverthROW
BUY SOME HATS --->
Old June 20th, 2012, 03:23 PM
Just throwing in a high output alternator without knowing the load on the batteries or the amp draw is senseless.
You have to calculate the total amp hours you need first then buy batteries that will provide the juice. Two 31 AGM batteries in parallel will give you quite a lot of reserve. You could run a small air conditioner on them.
Old June 20th, 2012, 03:46 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
The load is nominal I believe - I have a radio, Nav unit and a couple hella lights, a arb fridge and plan to charge a few phones etc - shouldn't the alternator be providing 13-14 volts to the battery to charge them regardless of 1 or 2 batteries?
Im not concerned how long I can run stuff with the engine off I'm only concerned that the alternator is not putting out enough volts to charge the batteries in the first place
what am I missing?
Old June 20th, 2012, 04:33 PM
You're confusing volts and amps for one. I would say that by the list you need no more than the stock alternator. You may want to go up in size on your battery bank.
Old June 20th, 2012, 04:49 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
confused is the correct word - shouldnt the voltage at the battery terminals be 13-14 to charge the batteries?
Old June 20th, 2012, 05:02 PM
Naplm00
Matthew
Yes, and the alt must also have the available current (in relationship to the varying load) to be able to charge the batteries.
If not you will be running off the batteries and not charging.
The voltages you showed before are low, i would check/replace ground and power wires with heavier gauge. then possibly buy a larger alt
alternator
Need Help Mean Green Alternator install Gore Ranger Defender Technical Discussions 8 September 25th, 2007 04:07 PM
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
Mean Green Alternator install tmore Defender Technical Discussions 4 May 11th, 2004 02:45 PM
