Mean Green or other HO Alternator - Page 2 - Defender Source
Old June 20th, 2012, 05:13 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
what gauge wire should be used for the alt to battery?
thanks
Old June 20th, 2012, 05:21 PM
Naplm00
Matthew
Well my charging circut on my early ROW truck was 2/0 gauge from the battery to the starter soleniod.
The alt has two 8 gauge wires from the rear to the same stud on the starter.
To be honest i realy dont remember 100%
I did replace my frayed and corroded engine to frame ground cable with a new 0 gauge cable and ends.
Old June 20th, 2012, 07:56 PM
There will be anywhere from 13.6-14.4 volts at the battery terminals with a healthy battery and the alternator charging. Think of the battery like a bank account. You take money out and you put money in. As long as you put in more than you take out, no problems. The Alternator is like your salary. Your radio, fridge and phones are like your bills. However in the case of your charging circuit, the currency isn't dollars, it's amperes.
So say your alternator is putting about 30 amps into the battery and you are only using 20, everything is great.
Alternators work by sensing the voltage of the battery. If this voltage falls below a certain point, the alternator turns on and charges. When the voltage gets high enough it turns off. Now the alternator is subject to engine speed as well. At low engine speeds, the alternator isn't making many amps. Even if it is charging, it is a very low rate so if the load is more than what is being put back, you are discharging the battery.
Two ways around that. Bigger battery bank or bigger alternator.
I won't even get into the advantages of a deep cycle and a starting battery and a split charging system.
Old June 20th, 2012, 09:52 PM
tpond
Toby Pond
110
"I won't even get into the advantages of a deep cycle and a starting battery and a split charging system."
I would love to hear your take on those things.
Old December 31st, 2012, 06:19 AM
davenrea
David
2010 puma. 90
If you want an easy option for charging two batteries and getting the most out of your existing altenator you can always fitt a battery to battery charger from http://www.sterling-power.com/products-battbatt.htm, makes your altenator work hard and charges batteries quicker. I run a winch of my second battery and two chargers and it works for me and keeps standard parts
alternator
Need Help Mean Green Alternator install Gore Ranger Defender Technical Discussions 8 September 25th, 2007 04:07 PM
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
Mean Green Alternator install tmore Defender Technical Discussions 4 May 11th, 2004 02:45 PM
