Maybe I'm an idiot... 2.5TD~200TDI - Defender Source
Old July 28th, 2015, 03:30 PM
champana
Richard Hardin
83 One Ten Hi-cap
So this is my first Rover diesel... Rover #14. It's an '83 One Ten with 2.5TD. From all of my reading, the Block, Crank, Timing/ Cover, Turbo, exhaust manifold, etc are the common between the 2.5 and the 200. Seems the only difference may the the injector system, head, maybe cam and pistons too... and some of the ancillaries. Is this correct? Is it feasible to drop those components on to my truck, add an intercooler, and be on my way?
Old July 28th, 2015, 04:00 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
NO YOU'RE NOT!
There are some other differences, but this is something I've been looking into myself.
The 200 has 2 major design flaws that were corrected with the 300 TDI:
The bridge between the valves is too small and head prone to cracking and the coolant passes through the front cover which is sealed by a gasket, so when the coolant is pressurized the cover gasket blows and requires you to completely disassemble the front of the engine including the entire timing assembly (belts. gears, IP, and so on).
I have a 2.5 N/A to tear down and see how to build it into a TDI engine.
Notice the TDI and not 200TDI because I want to use a 300TDI head, pistons, injectors, and figure out how to make a front cover or modify an existing one to use something similar to the 300TDI "P" gasket.
Also you'll need a lot of 200TDI parts: oil pump, lower stiffening girtle, oil pan, and so on.
It is also possible to use the 300TDI IP.
The big milestone will be the pistons as am not sure the 300TDI ones fit the earlier rods.
RDavisinVA
Old July 28th, 2015, 04:14 PM
champana
Richard Hardin
83 One Ten Hi-cap
Originally Posted by rdavisinva View Post
NO YOU'RE NOT!
I may actually be an idiot...
Thought this was interesting
https://www.landyzone.co.uk/land-rov...-block.171270/
Old July 28th, 2015, 04:33 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
From the link:
"Before you even think about putting a 300tdi cylinder head on a 200tdi block you will have to be prepared to take the pistons out and swap the piston heads for those to suit a 300tdi. The combustion chamber in the 300tdi piston crown is in a different position to that of a 200tdi to compensate for the angle that the 300tdi injectors enter the head. If you use 200tdi pistons, the combustion chamber is in a completely different place and the diesel will not burn properly."
Yes before knowing any better, I did fit a 300TDI head onto a 200TDI engine and while it seemed to run fine, it was probably not the best choice due to the differences in the pistons.
BUT
If you're going to have to rebuild the engine and need new pistons anyway, why not 300TDI ones if they fit on the 2.5 rods?
The 300TDI rockers, manifolds, valve covers, thermostat housing, and injection lines are not that hard to come by.
RDavisinVA
Old July 28th, 2015, 04:49 PM
champana
Richard Hardin
83 One Ten Hi-cap
From the link:
BUT
Right. Looks like people are using the 200/2.5 Front cover...
Old July 28th, 2015, 07:01 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
You are all mistaken! The 2.5 NAD is the gods promise that life is good ( and you will go deaf).! Who needs all that HP....really?
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old July 28th, 2015, 07:10 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I can't wait for you to drive the 4JB1-T 2.8 liter Isuzu 110 Turbo Diesel.
Was on the upgrade of an overpass Saturday on the way to Mark's house to pick up the porta-power.
Driving with a garman for accurate speedo (cable broke last week).
Behind someone going 56 MPH in the left lane when an opening to pass on the right came available.
Floored it as I pulled in the right lane looked down as I went in the left lane and was going 78 MPH.
This took place in about 3 seconds just before reaching the top, so all of it was up-hill.
RDavisinVA
Old August 1st, 2015, 07:35 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Why on earth would you want to make a 2.5 NA into a tdi?
Matt Browne
Old August 1st, 2015, 08:22 AM
HP is overrated when you have low range.....
200tdi, tdi
I'm an idiot and so can you! akfisher Misc. Chit-Chat 4 June 5th, 2013 01:54 PM
Fitting windscreen has me feeling like an idiot. ajh Defender Technical Discussions 17 March 31st, 2010 09:35 AM
Is it just me or is this guy an idiot? phoenix37 Misc. Chit-Chat 14 June 30th, 2009 12:42 PM
how to keep an idiot busy jimmy salmon Misc. Chit-Chat 1 February 17th, 2008 07:56 PM
Idiot Light Panel JJParker Wanted 0 March 16th, 2007 01:47 AM
