Maximum EGT for. GAS 4.2 - Defender Source
Old March 31st, 2011, 05:20 PM
cdb
Clark Bowen
working on ways to not toast a supercharged 4.2 and it occurred to me that keeping an eye on the temperature of each bank would be a very good idea.
It sure helps with my 300 TDI.
Does anyone know the temperature of the heads, exhaust manifold, or oil when I'd want an alert to go off?
2011 RR HSE -
2001 GMC 2500 4wd
Old April 1st, 2011, 06:11 PM
Ive never know people with boosted engines to run EGT's cept on diesels. Everyone I know with boosted gas burners run a air fuel gauge
Old April 1st, 2011, 07:20 PM
cdb
Clark Bowen
Yes, I was trying to come with a belt and suspenders approach, but the AFR gauges seem to be enough.
Sent from my iPad using Forum Runner
------ Follow up post added April 1st, 2011 04:22 PM ------
There should be an "up" after "come"
2011 RR HSE -
2001 GMC 2500 4wd
Old April 2nd, 2011, 12:23 PM
LRover's Avatar
LRover
J. Michael McCaig
The factory supercharged engines that I am familiar with use oil spray to cool the piston skirts. I don't know if the Rover V8 has those oil sprays but I think that keeping the oil cool (and effective) would be of upmost importance. I would want to also monitor the oil temperature.
Old April 2nd, 2011, 03:22 PM
TS888's Avatar
TS888
Tony Sims
1984 110
No oil sprayers in a Rover V8.
Tony
1984 110 "Smokey" (sold)
Old April 2nd, 2011, 06:33 PM
cdb
Clark Bowen
You should have seen how much oil it sprayed when I grenades the engine. The cloud of smoke from the exhaust and off the cats was truly monumental. I probably doubled the air born contaminants in New Mexico that day. Very embarrassing.
I thought about oil temperature gauge but decided my priority was detonation. I can't hear it, so I ordered two Knocklites - one for each cylinder bank.
Theoretically, they will alert me way before it becomes a serious issue. On top of that I ordered two AEM wideband O2 sensors - again, one for each side.
On the 1,200 mile trip back to Oregon I'll get to test the thinking. BTW, it was advice from this Forum under a different post that led me in this direction. Thanks very much.
Clark
2011 RR HSE -
2001 GMC 2500 4wd
gas
where do i get the 4.2 chip? vesparover Defender Technical Discussions 6 March 13th, 2006 10:21 PM
quick help needed 4.2 oil lines Abrooks Defender Technical Discussions 8 February 10th, 2006 02:38 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
4.2 RR engine neo812 Defender Technical Discussions 0 October 20th, 2003 11:11 PM
