Maxi fuse blues - Defender Source
Old May 20th, 2014, 01:22 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Maxi fuse blues
Hi, folks! My '98 ROW 300 TDI is blowing one of its 60 amp maxi fuses, the one that feeds the ignition switch, the interior fuse box and practically everything else. A quick visual check didn't show any obvious short. Is there any known problem area (I mean, as in more problematic than the rest) which I should check first when looking for the short?
BTW, while checking for voltage in the live connection on the fuse box, I also checked the dead side... and sure enough, I had a reading of about 6 volts, dropping rapidly to about 1V, and then slowly towards zero. If I replace the maxi fuse, take it out and check again, this shenanigan is repeated. Only with the ignition switch in "off". What could be causing this? Do I need to start stocking Lucas smoke?
Any help will be greatly appreciated!
Old May 20th, 2014, 01:46 PM
I might suggest asking at a UK forum. There will not be a lot of people on here with a 1998 or newer Defender, being a US based site.
Old May 20th, 2014, 01:49 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Yeah, I though so... So I went to the Series2club.... to find out that they ousted me for not posting in about a year. Time flies!
Old May 20th, 2014, 09:15 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The fuse block on the footwell part of the bulkhead I assume? I think that is directly fed from the battery but would have to look it up. It is hard to get to but I would disconnect the battery and then take the fuse block off and double check all of the connections. Sounds like you have a short. Not generally a problem area unless there is a bunch of corrosion.
Old May 21st, 2014, 09:38 AM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Yes, it is close to the brake servo. I dismantled it, and there are good news and bad news. The good: this is a modern, modular thing, easy to dismantle. The bad: there was no corrosion nor loose connections. The battery feed wasn't real tight- but not loose by any means.
Old May 21st, 2014, 06:46 PM
Capt Milks's Avatar
Capt Milks
Ok, trace the power lead back to the Battery especially where it enters the seat box. It just wont pop the fuse unless you are grounding out someplace. Has the starter been doing OK when it was not blowing the fuse? I would also check the connection on the starter.
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
Summer Blues pendy For Sale - Parts 30 July 17th, 2010 12:20 AM
Fuel injection system Maxi fuse blowing ? TND90 Defender Technical Discussions 4 August 24th, 2009 12:32 PM
3" Big Blues devinchi For Sale - Parts 1 March 8th, 2007 04:54 PM
New Car Blues Nategracie808 Defender Technical Discussions 12 July 18th, 2004 10:24 AM
