Math help for drivetrain please - Defender Source
Old September 17th, 2008, 11:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I know there are a couple math studs on here that can help me with this. I need to calculate top speed based on gear ratios. So assuming that the useable top speed on a 300TDi is 75mph stock, the numbers would go:
3.73 gears, (??) 1.4 t-case, 31in tires = 75 mph at a decent rpm about 3200-3500 I think.
So what would be the top speed of:
6.20 gears, 1.4 t-case, 40in tires = what at 3500rpm
Also, that would it be for:
6.20 gears, 1.2 t-case, 40in tires =??
Last:
6.20 1.0 t-case, 40in tires = ??
Standard r380 transmission in this. If that matters. This is only for gear ratio purpose. Thanks in advance!!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 18th, 2008, 01:10 AM
madcowdungbeetle
Carter
If no one has replied to this with some numbers, I'll run the calculations sometime in the morning when I get to work.
Old September 18th, 2008, 08:26 AM
6.2/3.73 * 31/40 = 1.29 i.e. engine will run 1.29 times faster for the same speed.
6.2/3.73 * 1.2/1.4 * 31/40 = 1.10
6.2/3.73 * 1.0/1.4 * 31/40 = 0.92
I estimate 3350 rpm for your base case.
So 3500 rpm for each case is:
78 mph
60
71
85
Old September 18th, 2008, 09:56 AM
madcowdungbeetle
Carter
Assuming you're running in 5th gear with an R380 for a TDI with a 0.77 5th gear:
@ 3500 RPM assuming an ACTUAL tire height of ~38"
1.4/6.2 - 59mph
1.2/6.2 - 69mph
1.0/6.2 - 83mph
I made an Excel spreadsheet I can post up if you like for your own person tweaking.
Old September 18th, 2008, 10:02 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Guys, thanks a ton, I really appreciate it.
Yes please!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
