mastercraft bench seat - Defender Source
Old January 12th, 2008, 08:11 PM
raychel batts
raychel batts
1995 defender
does the 36 in. bench seat fit in a 95 st defender? looks to be a tight fit. looking to go with the two front rubicon seats and back rubicon bench seat. saw plenty of good info on front seats but little to nothing on back bench seat. appreciate any help raychel
Old January 12th, 2008, 09:46 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yes, the 36 will slide in-between the wheel wells. But, you could fit a 40" if you lift it up a bit (it would be tight), which you should so your passengers have some leg room. 36" will fit two adults, as long as there midgets, and married.
Also, I say this every time, but PRP makes the same seat but is cheaper. I have both.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 13th, 2008, 11:28 AM
raychel batts
raychel batts
1995 defender
thats funny. thanks for the reply
also meant to ask , being that the center cubby has seen its best days, would it be wise to go with a narrower center console. i see that tuffy makes a narrower center console but they reccomend the 12 and half console. will the narrower ones fit? this would help with the wider 22 inch rubicon seats. is all of this neccesary? raychel
Old January 13th, 2008, 12:19 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
10in is realistically the widest you can fit. I have the 10in, I can post pics if you like. You may be able to get 12in in there but your seats would be rubbing it and they would be hitting the outside of the tub. If your tub is like mine (non nas), you will have the clearance the tub to make the seats fit properly. It's not a big deal. Also, I wanted to run stock seatbelts, those would not fit with the 12in wide tuffy.
Is it necessary? Yes, these are the best and the safest seats you can own. But if you don't wheel, no. They are harder to get into than a standard seat and on long trips, they leave a little to be desired in comfort. If I never wheeled, I would have thrown seats in there from an acura or the like.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 13th, 2008, 03:30 PM
raychel batts
raychel batts
1995 defender
always greatful for your advise thanks raychel
bench, master
mastercraft rear seat tbmcneill For Sale - Parts 2 November 10th, 2005 02:40 AM
Surrey top, rear bench seat, and front guard klcarvalho For Sale - Parts 9 October 21st, 2005 12:45 PM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Wanted: Forward facing rear bench seat zed111 Wanted 0 July 26th, 2004 01:52 PM
