Master Clutch Cylinder Replacement: Questions... - Defender Source
Old February 8th, 2011, 12:19 AM
NC Rover
Nick
1971 Series IIa Hybrid
Hey guys...I'm in the process of trying to replace my master cylinder.
Here's what I have:
-'71 Series IIa body on a D90 galvy frame
-2.5L Milspec 5 main bearing engine
-D90 axles
-D90 front disc brakes
-LT 77 tranny / LT230 xfer case
So, with that said, you will notice that the master clutch cylinder is tucked up under the driver's side wing. Tough to get to...no room for top down removal without removing the fender..which I plan on doing.
For the longest time, the clutch pedal engaged fairly close to the floor. The master cylinder always had a slight leak but I never could figure out if that was the issue, or the clutch was on its last leg. As of recent, it began to leak down the clutch pedal more than usual...and after bleeding several times, the clutch engages right off the floor.
I'm replacing the master cylinder but after opening the top, I noticed that its kind of rigged in there...not like what I've found pictured in the DIYs (http://landytown.myfastforum.org/arc...t__t_4893.html) floating around the internet. I was going to try and adjust the pushrod so the clutch would engage a bit further off the floor but it looks like I have no room left. Any suggestions on this and how I could go about gaining a bit more room to adjust the plunger?
Old February 8th, 2011, 07:05 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
The last time I replaced a master cylinder on my 90, I unbolted the brake assembly from the bulkhead and moved that aside - brake lines were not disconnected. That left just enough room to remove the clutch assembly.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old February 8th, 2011, 10:06 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The only thing funky that I see if that 12 point nut and big washer. It should be an identical nut to the one on the MC side of the pedal trunion and a thin washer. When you put the new one in you will have plenty of adjustment available to set it up correctly.
Old February 8th, 2011, 10:36 AM
Pull the fender - it's really easy on the IIa body. As Kevin says the new one should have a threaded rod with nuts on both sides to allow you to adjust it.
Can we see some more pics of your rig?
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2011, 03:06 PM
NC Rover
Nick
Thanks everyone. I may move the brake assembly as Hoosier suggested. It probably wouldn't hurt to replace the master brake cylinder as well.
I have several maintenance items I just ordered to replace before spring gets here.
Anyone have any links to any good DIYs on pulling the transmission/xfer case? I'd like to replace the clutch and some of the gaskets.
Cgalpin - here are some more pics of my setup.
Old February 8th, 2011, 03:11 PM
I love it. It looks like that bumper is setup for a husky too
ac, clutch, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
WTF... Fourth clutch master cylinder in 5 years ? JFD Defender Technical Discussions 6 June 23rd, 2010 09:59 AM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
